603,839 active members*
4,426 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion
IndustryArena Forum: Linear and Rotary Motion
Page 33 of 131 2331323334354383
Threads 641 to 660 of 2611
Discuss ball/Acme screws, R&P, linear slides and theory here.
  1. Sticky Thread Sticky: Ballscrew Basics
    Started by Swede, 03-01-2005 05:06 PM
    8 Pages
    1 2 3 4 5 ... 8
    06-25-2025, 03:36 PM Go to last post
  2. Sticky Thread Sticky: Servo or Stepper for CNC?
    Started by CNC_Kid, 02-05-2006 08:37 PM
    4 Pages
    1 2 3 4
    cnc, cutting, plasma, run, servo, wan
    08-06-2021, 02:21 PM Go to last post
    03-16-2021, 08:26 PM Go to last post
    11-09-2014, 06:32 PM Go to last post
  1. Exclamation another ballscrew question
    Started by nokillzone, 11-01-2014 04:35 AM
    ..., 600, ballscrew, bridge, building, dimensions, diy cnc router table machines, fast, heavy, linear, machine, made, models, motors, nema, part, please help me !, price, question, revolution, shaft, size, speed, star
    11-04-2014, 03:06 AM Go to last post
  2. Scissor arm Z axis?
    Started by strangetanks, 11-02-2014 01:41 PM
    arm, articulated, axis, bearings, bosch, build, cnc, cnc router, current, dust, fine, linear, machine, maintenance, movement, new cnc, new cnc router build, rigid, router, small, switch, thoughts, wanted, z axis
    11-03-2014, 01:42 PM Go to last post
  3. used nsk ballscrews
    Started by dholzric, 10-29-2014 08:35 PM
    10mm, 3d printer, 503, ballscrew, ballscrews, cnc, cnc router, cnc router., hey, king, measured, nsk, number, part, printer, router, small, small cnc, suitable, thinking, turn
    10-29-2014, 08:35 PM Go to last post
  4. Machine Build ball screw mount question
    Started by chevydyl, 10-26-2014 03:55 AM
    1100, 2000, ball, ball screw, bosch, build, build log, drive, end, fast, head, machine, mill, mount, needed, parts, rails, screw, star, steps, supported, table, tormach
    10-27-2014, 03:07 AM Go to last post
    10-21-2014, 01:45 PM Go to last post
  5. Box way cnc mill build using reclaimed ways
    Started by joedesu1, 10-16-2014 05:56 PM
    axis, ball screw, bearings, box, build, cnc, cnc mill, diy, feed, grinder, grinding, holding, machine, mill, parallel, precision, shop, steel, surface, table, things, ways, wondering
    10-20-2014, 08:54 AM Go to last post
  6. Cheap ballscrew runout
    Started by yoshimitsuspeed, 09-08-2014 06:12 PM
    aluminum, ballscrew, cheap, cnc, common, cut, cutting, diy, diy cnc router table machines, fast, machine, metal, nuts, plastic, post, problem, product, rail, runout, section, stainless, woodworking
    10-20-2014, 08:40 AM Go to last post
  7. Tool room bed mill B axis design
    Started by EFI-Unlimited, 10-12-2014 01:56 PM
    10-17-2014, 01:01 AM Go to last post
    10-14-2014, 01:29 AM Go to last post
  8. Ballnut - Odd number of balls? WTF?
    Started by Wallybanger, 10-03-2014 01:56 AM
    1605, back, ball, ball bearings, ball nut, ball screw, ballnut, balls, bearings, choice, close, confused, full, make, number, nut, quiet, screw, sense, smooth, thing, tracks, work
    10-12-2014, 08:20 PM Go to last post
    10-09-2014, 04:07 PM Go to last post
  9. MGN15 lubrification
    Started by Yaro, 10-06-2014 04:04 PM
    bearing, bit, carriage, chinese, friction, hi all, linear, linear rail, lit, move, plastic, precision, put, questions, rail, rails, sbr, smooth, stop, swi, type, vertical, weight
    10-06-2014, 04:04 PM Go to last post
  10. Belt linear actuator
    Started by montreal333, 10-01-2014 09:42 PM
    10-02-2014, 04:37 PM Go to last post
  11. Should I use AG30 or EG15
    Started by Dman65, 09-29-2014 05:53 PM
    4x8, ag30, bit, current, eg15, foot, generation, hat, heavy, heavy duty, legacy, lol, medium, overstock, rack, rail, rails, router, section, sight, track, wondering, worse
    09-29-2014, 05:53 PM Go to last post
  12. Cleaning a ball screw
    Started by chevydyl, 09-23-2014 01:20 AM
    ball, ball screw, clean, cleaning, gummy, housing, issues, lube, lubricant, nut, part, pump, rails, resistance, rexroth, run, screw, smooth, stick, supports, thing, turn
    09-26-2014, 08:11 PM Go to last post
  13. Single axis motion
    Started by amo, 09-24-2014 01:33 PM
    09-25-2014, 03:05 PM Go to last post
  14. Ball nut twist play
    Started by chevydyl, 09-23-2014 04:28 AM
    09-25-2014, 04:40 AM Go to last post
    09-24-2014, 07:41 AM Go to last post
  15. Need opions for my auction fail.
    Started by lowpull, 06-24-2014 04:37 AM
    09-21-2014, 06:34 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 33 users browsing this forum. (0 members & 33 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
