603,861 active members*
3,863 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion
IndustryArena Forum: Linear and Rotary Motion
Page 32 of 131 2230313233344282
Threads 621 to 640 of 2611
Discuss ball/Acme screws, R&P, linear slides and theory here.
  1. Sticky Thread Sticky: Ballscrew Basics
    Started by Swede, 03-01-2005 05:06 PM
    8 Pages
    1 2 3 4 5 ... 8
    06-25-2025, 03:36 PM Go to last post
  2. Sticky Thread Sticky: Servo or Stepper for CNC?
    Started by CNC_Kid, 02-05-2006 08:37 PM
    4 Pages
    1 2 3 4
    cnc, cutting, plasma, run, servo, wan
    08-06-2021, 02:21 PM Go to last post
    03-16-2021, 08:26 PM Go to last post
  1. DIY anti-backlash nut?
    Started by Carniflex, 01-04-2015 09:22 PM
    01-06-2015, 02:55 AM Go to last post
  2. Preloading of ballscrews without thread
    Started by joedesu1, 01-03-2015 06:16 AM
    advice, ballscrews, expensive, greatly, preload
    01-06-2015, 02:46 AM Go to last post
  3. 4th axis bearing arrangement.
    Started by Feff, 11-27-2014 06:05 PM
    01-05-2015, 10:02 PM Go to last post
    01-01-2015, 09:30 PM Go to last post
  4. fixed pinion?
    Started by Yurtman, 12-31-2014 07:23 PM
    cnc, drives, fixed, linear, pinion
    12-31-2014, 08:50 PM Go to last post
  5. sbr truck question
    Started by minichopper6hp, 12-28-2014 02:53 PM
    adding, advantage, axis, diy cnc router table machines, flex, hose, inches, question, rail, sbr, slop/flex, trucks
    12-28-2014, 09:52 PM Go to last post
  6. Vertical Wall Engraver
    Started by mikemunoz07, 12-28-2014 01:54 AM
    build, cnc, cnc machine, due, engrave, engraver, engraving, exis, existing, gravity, hat, ing, machine, mobile, new to cnc, por, portable, portable cnc, surface, surfaces, ver, vertical, verticle, wall
    12-28-2014, 01:54 AM Go to last post
  7. Moved: Driving dual lead screws on the same axis....
    Started by SatanKlawz, 12-25-2014 06:04 PM
    axis, belt, build, diy cnc router table machines, drive, driving, dual, g54, g540, gecko, gecko g540, how to, input, lead screws, long, new build, screws, setup, steppers, timing, timing belt, wanti
  8. Driving dual lead screws on the same axis....
    Started by SatanKlawz, 12-24-2014 08:02 PM
    2 Pages
    1 2
    axis, belt, build, drive, driving, dual, g54, g540, gecko, gecko g540, how to, input, lead, lead screws, long, new build, screws, setup, steppers, timing, timing belt, wanti
    12-25-2014, 08:14 AM Go to last post
  9. Advice on best motion.
    Started by jbobrout34, 12-25-2013 12:58 PM
    12-24-2014, 04:46 PM Go to last post
  10. HIWIN HGH20CAC blocks, looking for online
    Started by Konstantin, 12-23-2014 06:46 AM
    998, blocks, buy, chinese, ebay, engraving, experience, hgh20cac, hiwin, ice, large, led, linear, long, machine, nice, offer, online, price, product, rails, silver
    12-23-2014, 06:46 AM Go to last post
  11. Profile Rail, 2 race vs 4 race lm guides
    Started by blitz355, 12-17-2014 02:40 AM
    501, 80/20, aluminum, aluminum extrusion, axis, build log, cut, cutting, design, drive, gantry, guides, machine, profile, race, rail, rails, size, star, steel, support, wood
    12-18-2014, 10:43 PM Go to last post
    12-14-2014, 12:51 AM Go to last post
  12. Trying to locate source for v-rail insert
    Started by chasxjs, 12-09-2014 11:47 PM
    12-13-2014, 11:18 PM Go to last post
  13. Question Need a new stepper
    Started by Brad_cnc, 12-10-2014 10:17 AM
    12-10-2014, 10:17 AM Go to last post
    12-10-2014, 09:49 AM Go to last post
  14. wrong place ?
    Started by objones, 12-06-2014 02:11 AM
    000, 048, 200, 2000, 2048, coder, don, encoder, forma, formation, hey, information, ion, line, optical, place, pos, reading, rotary, rotary encoder, work, wrong
    12-06-2014, 02:11 AM Go to last post
  15. Servo sizing software
    Started by MechaGj, 12-05-2014 03:11 PM
    appreciated, can, consideration, ding, finding, hat, help, ion, motion, motor, servo, size, sizing, softwar, software, suggestions, taking, tha, variations, war, ware
    12-05-2014, 04:22 PM Go to last post
  16. Bent Ballscrews (another one)
    Started by kostas1, 11-03-2014 11:58 AM
    2 Pages
    1 2
    12-02-2014, 08:53 AM Go to last post
  17. Belt drive design woes
    Started by taiden, 11-12-2014 07:01 PM
    10mm, 3/8, ballscrew, belt, belt drive, belts, design, drive, gear, interact, missing, motor, problem, pulley, rpm, shaft, size, stepper, stepper motor, timing, timing belt, trapezoidal
    11-14-2014, 07:05 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 7 users browsing this forum. (0 members & 7 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
