603,311 active members*
3,299 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Oct 2005
    solution to salvados board
    Hi was there a solution to afferriers problem with salvados board, i would like to make it.
    thanks a lot
  2. #22
    May 2005
    1397
    This is NOT a linistepper
    First, let me point out that this thread is named in error: This board is NOT a linistepper but a new board BASED on the Linistepper. I would really appreciate it if the people who run this site would edit the name of the thread to remove the Linistepper name. The actual Linistepper
    http://www.linistepper.com works just fine and is open source. You can make the board from the layout published on the official site or buy the pre-made board and it WILL work. There are no problems.
    Second, no, there is no correction to this board. It is apparetly flawed and not useable in the first place. The actual linistepper board, with it's open source layout, source code, and design DOES work. Please do not be confused by the problems afferriers had with this board. The actual linistepper board has NO problems; it works just fine.
    There are also many other open source stepper controllers that do work.
  3. #23
    Jan 2010
  4. #24
    Mar 2012
    I have build PIC linear stepper on pcb and testing will be on Saturday, one thing that i noticied when i compare this two schematic is that resistor on MCLR pin must be just jumper becuse that is in original schematic...
    I will replay on Saturday when i test the board...
    Here are some pictures...
  5. #25
    May 2005
    1397
    I hope you used a proven design and not the salvado layout which doesn't seem to work for others.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  6. #26
    Dec 2015
    Re: Linistepper new board
    hola hace unos meses que empece con este tema del cnc y ahora estoy incursionando sobre este tema de los micropaso, quieriera saber alguien podria pasarme el hex para grabar el pic de este driver?, saludos y gracias!
  7. #27
    Dec 2015
    hello few months I started with this theme cnc and now I'm dabbling on the subject of microstepping , quieriera know someone could spend the hex to record the pic of this driver does ?, greetings and thanks !
Page 2 of 2 12
  1. Issue with a linistepper
    By Serhio in forum Open Source Controller Boards
    Last Post: 01-05-2013, 09:50 PM
  2. Linistepper in C
    By hazimin in forum PIC Programing / Design
    Last Post: 01-24-2011, 03:34 AM
  3. I think i am going the Linistepper route
    By phantomcow2 in forum PIC Programing / Design
    Last Post: 03-14-2009, 06:19 PM
  4. My linistepper-a true GEM
    By student1616 in forum Open Source Controller Boards
    Last Post: 12-02-2008, 05:59 PM
  5. Linistepper
    By tante in forum Open Source Controller Boards
    Last Post: 12-19-2005, 04:24 PM
