603,839 active members*
3,047 visitors online*
IndustryArena Forum: LinuxCNC (formerly EMC2)
Page 2 of 70 12341252
Threads 21 to 40 of 1389
Discuss LinuxCNC (formerly EMC2) Controllers here!
  1. Sticky Thread Sticky: EMC Video gallery (See what others are doing with EMC)
    Started by ynneb, 07-03-2008 04:26 AM
    2 Pages
    1 2
    09-20-2014, 04:45 PM Go to last post
  1. "Test this axis" - unexpected result
    Started by greybeard, 01-28-2010 05:27 PM
    03-29-2022, 10:26 AM Go to last post
  2. Problem with homing
    Started by vph, 03-19-2022 02:39 PM
    03-27-2022, 04:05 PM Go to last post
  3. Lathe tool and work offsets
    Started by bluebumper, 03-26-2022 07:15 AM
    cnc, lathe, piece, set, tools
    03-26-2022, 11:16 AM Go to last post
  4. Linuxcnc retrofit to Avidcnc plug and play
    Started by FredG, 01-30-2022 12:14 AM
    avidcnc, cnc, forum, linuxcnc, mesa
    01-30-2022, 08:51 PM Go to last post
  5. First CNC, Lots of Questions...
    Started by michael_giesbre, 12-27-2007 06:18 PM
    available, cnc., everyone, fiddling, its, maybe, mos, not
    01-24-2022, 12:40 AM Go to last post
  6. lathe tool and work offsets
    Started by llilrex, 12-12-2021 06:17 PM
    diameter, offset, set, tool, touch
    01-07-2022, 07:39 AM Go to last post
  7. Linuxcnc + MESA 7i92h + pmdx126
    Started by sagreen, 12-08-2021 09:16 PM
    7i92, linuxcnc, mesa, pmdx126, pncconf
    12-08-2021, 09:16 PM Go to last post
  8. Latency test
    Started by Jamie84, 11-27-2021 10:18 PM
    run, latency, running, test, glx
    11-28-2021, 04:15 PM Go to last post
  9. Reversing axis direction in linuxcnc
    Started by Goemon, 04-22-2021 03:28 PM
    axis, direction, linuxcnc, making, read
    11-16-2021, 09:53 AM Go to last post
  10. How big was the correction per axis when homing ??
    Started by vroemm, 11-10-2021 08:28 PM
    automatic, homing, pos, touch, vroemm
    11-10-2021, 08:28 PM Go to last post
  11. Needing some help
    Started by Jamie84, 11-06-2021 12:57 AM
    cnc, video, wondering, information, real
    11-06-2021, 12:57 AM Go to last post
  12. Question Linux CNC Servo motor help...
    Started by CplUSMCRetired, 10-17-2021 10:17 AM
    cnc, custom, linux, motor, servo
    10-18-2021, 12:00 AM Go to last post
  13. Lightbulb gcode and gmoccapy
    Started by Fiury, 09-03-2021 11:30 AM
    09-06-2021, 09:02 AM Go to last post
  14. Unhappy Joint xx following error!
    Started by azant, 05-10-2021 10:15 PM
    max_acceleration, max_velocity, net, servo-thread, software
    05-14-2021, 10:18 PM Go to last post
  15. LinuxCNC 2.8.0 is released
    Started by andypugh, 09-09-2020 10:17 AM
    based, chris, john, linuxcnc, support
    03-22-2021, 04:37 PM Go to last post
  16. Wotan Rapid 1 HBM retrofit
    Started by deerefanatic, 01-26-2021 07:19 PM
    axis, cnc, linux, machine, thread
    03-11-2021, 03:03 PM Go to last post
    03-08-2021, 08:40 PM Go to last post
  17. EMC control of airbrush bot
    Started by Bastiaan, 11-14-2009 03:10 AM
    down, its, maybe, not
    02-25-2021, 09:27 PM Go to last post
  18. malfunction during homing
    Started by rccroberto, 02-04-2021 09:41 PM
    axis, linuxcnc, malfunction, moves, software
    02-04-2021, 09:41 PM Go to last post
  19. The basics
    Started by Hopefulbull, 10-04-2020 03:30 PM
    cnc, direction, great, looked, years
    10-11-2020, 06:58 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 11 users browsing this forum. (0 members & 11 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
