I have bought 2 cnc routers which were originally used on a 3p 380V net and want to install them on a new location. The net on the new location is 3phase 220V. Now I have 2 options:
Solution 1: installing an expensive step up transformator to create 3phase 380 out of our network and just connect everything as it was. 2 problems: expensive and a lot of loss in the conversion.
solution 2: convert the cnc to 3phase 220V. for the drives and internal electronics no problems, there is already an internal transfo (Juche BK 800) installed that can be reconnected from 380 to 220. So internals are ok, but the spindle and vfd are a problem. the spindle is an HSD at/mt 1073-120 a 3p/380V spindle (which as far as I know can't be converted to a 3p/220V spindle. So my idea was to install a new vfd that converts 3p/220V to 3p/380V. I can't find any decent vfd which converts 3p/220 to 3p/380 only single phase 220 to 3p/380. Any suggestions?
the spindle
Attachment 514084
the vfd
Attachment 514086
the internal transfo for internal electronics, steppers and drives
Attachment 514088
