Forgive the newbie questions as I've been using the search function for 4 hours now and haven't seemed to have found an answer (and it's getting a little late).
Is there a DIY laser scanner project (or low cost unit), mountable to my 3-axis CNC, that I can do 2.5D scans with? I've read tons of stuff but it all seems to be geared to the David-laser scanner, etc. type set-ups for 3D scanning and use the 90 degree board behind it.
I would like to be able to lay something flat on my CNC bed and have the machine zip back and forth, make the scan and then I import the file into Cut 3D. My machine is a CNC Shark Pro and I've pulled my hair out using the Nextwave Touch Probe (been through 2 of them now and none seem to work right, even with consulting the manufacturer).
I've seen expensive and very expensive products from companies like Scantech, etc. but they are waaaaay outside of my barebones budget.
I've also looked into video probing...maybe that's a better option?
Any guidance would be greatly appreciated. I realize that newbie questions are headaches. Please be gentle...I may be an idiot, but a well meaning one.
The equipment that I'm using:
CNC Shark Pro
Cut 3D
V-Carve Pro 6.5
Mach 3 (not hooked up yet due to ncPod headaches)
Many Thanks!
Chris
