603,939 active members*
1,601 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Lubricating linear bearings (supported rails)
Results 1 to 4 of 4
    Jun 2009
    122
    Has any one worked out a way to efficiently lubricate the bearings that run on supported rails?
    Yes, I can always remove them and repack and reinstall, but this can be a bit of a pain.
    My Idea was to drill and tap a hole in the aluminium block for a grease nipple, than try and die gind through the outer case of the bearing (offline to the ballrace) and use these to inject grease when required.
    Any thoughts?
    Attachment 265062Attachment 265064
    May 2005
    3920
    Re: Lubricating linear bearings (supported rails)
    Does the insert have any porting for grease or oil lube?
    Jun 2009
    122
    No, that would be too easy!
    May 2005
    3920
    Rats!
    Maybe my mind is fuzzy but I thought some of the bearings we use at work where ported for lube. Maybe I'm thinking of something else. The funny thing is Thompson stresses the importance of lubrication in their data sheets. Maybe they have a detailed answer on how to do this properly with installed bearings.
    Your other option would be to keep the rails wiped down with an oil or grease. The wipers will push most of it away but there should still be a film left on the shaft.
  1. Aluminum supported linear rails
    By snowluck in forum DIY CNC Router Table Machines
    Last Post: 01-18-2014, 09:40 AM
  2. Glacern linear bearings/supported rails???
    By MasterMaker in forum DIY CNC Router Table Machines
    Last Post: 05-02-2010, 10:03 PM
  3. Glacern Supported Linear Rails & Bearings
    By Glacern in forum Linear and Rotary Motion
    Last Post: 02-12-2010, 07:35 PM
  4. Lubricating linear bearings
    By millman52 in forum Linear and Rotary Motion
    Last Post: 03-12-2009, 06:11 PM
  5. 16mm vs. 20mm supported linear rails...
    By WilliamD in forum DIY CNC Router Table Machines
    Last Post: 12-20-2008, 12:37 AM
