603,884 active members*
5,600 visitors online*
    Question Mach 3 Cycle Start Button Configuration
    Morning everyone,
    I a m running a CNC Router Parts CNC Benchtop Pro router with Mach 3. I am trying to configure a push button for the cycle start command. I already tried to do the following and no success:
    1. Assign the port and pin to OEM code 1.
    2. Assign OEM Code to 1000 to Trigger 1
    3. Attach switch to appropriate pin on you breakout board"pin 12 in my case" Port 1
    4......Nothing
    Please help. Does anyone else have the Benchtop Pro router hooked up with a cycle start button?
    Jan 2007
    24
    Re: Mach 3 Cycle Start Button Configuration
    I have seen that someone used I-pac card to connect arcade style push buttons to PC/Mach3
    Here is link: https://www.ultimarc.com/ipac1.html
    Sent from my LG-H872 using Tapatalk
    Thanks for the help!
  1. WATERJET CYCLE START BUTTON PROBLEM
    By isheeeljan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-23-2015, 06:31 AM
  2. 5020L...cycle start button...replacement brand?
    By Voss_Machine in forum Okuma
    Last Post: 12-13-2013, 06:31 PM
  3. MACH 3 cycle start button
    By Rick7702 in forum Mach Mill
    Last Post: 05-21-2013, 11:49 PM
  4. External Cycle Start button
    By Jerry Shorter in forum LinuxCNC (formerly EMC2)
    Last Post: 06-07-2010, 07:59 PM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
