603,308 active members*
2,962 visitors online*
Page 2 of 76 12341252
Results 21 to 40 of 1506
  1. #21
    Mar 2003
    35494
    Still working on the toolbar.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  2. #22
    Jun 2005
    45
    LOVE your screens, any possibility of a sample of the non flash version?
  3. #23
    Jan 2008
    241
    Looking AWESOME Gerry!
    Can't wait for the release date!!
    Chris
  4. #24
    Mar 2003
    35494
    Adding tabs
    Have a few of the tabs done. The screen will use Big Tex's Auto Zero routines. Next best thing to an ATC.
    Attached Thumbnails Attached Thumbnails 2010V3-2.jpg   2010V3-3.jpg   2010V3-4.jpg
    Gerry
  5. #25
    Apr 2006
    3498
    OMG.. Thats going to really a great screen.. .. Implementation of Super-PID speed control through Mach3, Auto Tool Zero setter really made it useful.. But, Gerry you have to help me out that Auto Tool setter things...
    Edit:
    My Auto Tool Zero is working ..thanks
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  6. #26
    Nov 2004
    436
    Ger,
    That thing looks great! Count on a donation from me when it is finished.
    Will there be a page or place for user LED's (future customization by the end user) ?
    Please consider a "verify" button. I like to use that when my machine has been running a while, to make sure I have not lost position.
    Rob
  7. #27
    Mar 2003
    35494
    Can you be more specific?
    I guess I can leave a blank tab? It's full right now, but I can drop one of them. I think I'll get rid of the 2D probing.
    Also, the tab key will open a large diagnostics screen. I can leave some space on it for you.
    Is that a regular Mach3 function? I don't see a button for it on the regular mach3 screen? Here's what I'm thinking. I have a bunch of space on the "Run" tab, so I'll replace the rewind with 4 smaller buttons, and make one of them Rewind, and leave 3 for users to modify. All you'll need to do is add text and a blank (transparent) button in Screen4.
    If you have any other ideas, give em to me quick. I'm at the point where changes are a big PITA.
    Here's where it stands right now.
    Gerry
  8. #28
    Jan 2008
    932
    Looks great Gerry. Will it have the normal jog mode commands (ie, the hotkeys will work)?
    Guessing the answer is yes, but if not, I'd definitely like them as I have gotten to where I prefer single micro step jogging to zero the z instead of the touch plate....
    Paul
  9. #29
    Mar 2003
    35494
    Yes, the arrow keys and pageup/pagedown will work with any tab open. It'll have 5 different user defined increments that the buttons and hotkeys will cycle through. What I do now is jog down at 100% 'til it's close, then hit a key to change it to 10%, then when it's really close I hit another key and it switches to .002 increments.
    Although I plan on switching to Auto Zero soon. What don't you like about the auto zero?
    Gerry
  10. #30
    Jan 2008
    932
    About one out of every 10 times I use it, the bit goes down nice and slow, makes contact, and instead of going up, it drives the bit down into the touch plate, breaking smaller bits.
  11. #31
    Nov 2004
    436
    Ger,
    The verify button is found on the MDI page, standard (default) mach screen. I use it to determine if I have lost any steps, or if any of the mechanicals on my machine are loose.
    As far as the user LED's: My machine will have a few position sensors for the dust-boot, and the second x-axis, etc. I thought that I needed to set up custom LED's on the diagnostics page, so that I can do brain functions/macro's based on their status. I might be thinking about it too hard though.
    Great Job!
    Rob
  12. #32
    Mar 2003
    35494
    Found it after I posted.
    I like this a lot more, and made it more appealing to a wider audience.
    Gerry
  13. #33
    Mar 2003
    35494
    I've got a few people testing it now. It shouldn't change too much now. But I do have room in the toolbar for several more buttons.
    It's going to be $20 when I finish it. If there's enough requests for specific features, I may end up with multiple versions, as it's fairly easy to change a single tab.
    I'll also be adding a 4 axis version as soon as it's done. The axis DRO's will be a little smaller, though.
    Attached Thumbnails Attached Thumbnails 2010V6.jpg   2010V6-2.jpg   2010V6-3.jpg   2010V6-4.jpg
    Gerry
  14. #34
    May 2006
    1469
    Quote Originally Posted by Arbo View Post
    Sounds like you are using a zero script that is suspect. There are plenty floating around the web.
    PM me your script and I will take a look.
    Greg
  15. #35
    Jan 2008
    932
    Looks good. I wonder how it will look on my screen out in the shed. Guess I should copy the files you put up before and take it out there and make sure it looks ok before buying it. (I have a wide screen in here, which stretches things and makes it not so pretty)
    Oh, what is initial autozero and initial autozero + tool change?
  16. #36
    Jan 2008
    932
    I was using the aussie tool setter one... but I'm using your blue screen now, so whatever that one is.
  17. #37
    May 2006
    1469
    I don't know any thing about blue screens, but the offer stands if you want to PM me.
    Greg
  18. #38
    Jan 2008
    932
    Oh sorry, I thought Gerry had written that post... mind blank.
  19. #39
    Mar 2003
    35494
    It needs to be run at 1024x768, with Auto Screen enlarge turned off in Mach3 so it doesn't get stretched. On a widescreen, it should just take up a portion of the screen. If you let it stretch, the text get's very blurry.
    I removed the sample I had posted, and will make a new one when it's done.
    The screen will be set up to use the auto zero macro's from Big Tex.
    The initial button is to auto zero with the first tool, then reference to a fixed touch off plate.
    The tool change button runs the M6 macro, which will move to a tool change location, wait for you to change the tool, then autozero to the fixed plate and resume cutting. Basically no interaction needed when changing tools other than pressing cycle start.
    I'll probably have an alternate version with "standard" tool change options as well. The separate tabs will make it easy to customize for different applications. Any modifications made will be included.
    Gerry
  20. #40
    Jan 2008
    932
    Ah, I just saw that from a link in CarveOne's thread. Looks cool, and very useful for most of the stuff I do. I'd have to learn to program in tool changes (whatever codes those are), but would be handy. Guessing it does the first touch as the real zero, then the second so it references where the real z is when you switch tools.
    I look forward to using that, as z zero at times has been my worst enemy.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
