603,826 active members*
4,650 visitors online*
Page 7 of 76 567891757
Results 121 to 140 of 1506
  1. #121
    Mar 2003
    35494
    How did you get around your grounding issue?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  2. #122
    Feb 2009
    499
    Still using a clip-on clamp on the collet nut, but that's pretty clumsy now, especially having to be right there to grab it right after the tool change setting, so I do intend to do something about it. Before, I guess I was reluctant to run a wire down near the collet just because it would get in the way of removing the router when necessary, and the way the mount surrounds the case. Now, with the mod for the SuperPID and its wire, I guess that's kind of silly. I'll be attaching one to the base soon.
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
  3. #123
    Mar 2003
    35494
    Added simple auto zero
    I added a download link on my site for an alternate "simple" auto zero macro.
    For those that don't need the toolchange auto zero and 2 plate setup, this will allow you to just do a single auto zero.
    It also still supports the optional material offset, and the retract height is user definable via the Clearance Plane DRO.
    Gerry
  4. #124
    Jan 2008
    932
    Is it an either/or thing, or can both be used in the same screens?
  5. #125
    Mar 2003
    35494
    One or the other for right now, but if you want both, I can add another button on the toolbar I guess.
    Gerry
  6. #126
    Jun 2003
    2103
    tagged
    No greater love can a man have than this, that he give his life for a friend.
  7. #127
    Feb 2009
    499
    Well, it seems the Colt uses some kind of ceramic bearing. I have no connectivity between the collet and bit to any part of the case. Not sure now how to avoid having a clip on the collet when zeroing. :tired:
  8. #128
    Mar 2003
    35494
    I wouldn't think it's a ceramic bearing, as replacements are only $5. (I just checked)
    Looking at this pic, http://www.ereplacementparts.com/ima...2609110220.gif it looks like the bearing is mounted in plastic to isolate it. Perhaps you can disassemble it, and drill a hole and get a wire to contact the outside of the bearing? Just a guess.
    Gerry
  9. #129
    Feb 2009
    499
    Not a bad guess, thanks for checking, Gerry. Perhaps I'll try to squeeze something in there. Probably ought to change the bearing as long as I'm there, anyway.
    Actually, I'm doing this only because I don't want to change the mount. If I did, what is the "cleanest" router for grounding/SuperPID mods - I mean easiest to do? Any feeling for that? I went with the Colt only because it was light and had the best runout.
  10. #130
    Mar 2003
    35494
    New Feature
    Anyone have a use for something like this?
    Gerry
  11. #131
    Jan 2008
    932
    I don't use that stuff too often, but I'm sure others probably do. The only thing I was going to do, when I got a chance, was make a little Icon to put on the top bar by the M6 stuff for just a normal z autoprobe like I used to do before the tool change. Figure every now and then I'll still be using it. Add the newest z code to the button and all.
  12. #132
    Aug 2007
    558
    Absolutely.
    I think it would be extra useful if there was a setting for probe offset so that I could use a non-spindle mounted probe. I'd need to work out how to activate it though (I want it to retract when not in use).
    Regards,
    Jason
  13. #133
    Mar 2003
    35494
    Quote Originally Posted by Arbo View Post
    It's already done. I'll be sending it out to users in the next week or two, but I wanted to get the probing done first. I don't have the installer set up, but I can send you the files if you want it sooner.
    Gerry
  14. #134
    Jun 2003
    2103
    Quote Originally Posted by Jason3 View Post
    Absolutely.
    Regards,
    Jason
    Jason would a little air cylinder activated via a mcode work for this?
    Mike
  15. #135
    Aug 2007
    558
    Quote Originally Posted by turmite View Post
    Mike
    Yes, perfectly thanks Mike. That's what I was hoping to use.
    Regards,
    Jason
  16. #136
    Feb 2009
    499
    I take it that the center button with the plus sign would be used to center the bit in a cylinder, i.e., go x+ until touch, go back to start, go x- until touch, go to distance/2, then do the same for y?
    I did use that occasionally to auto zero x,y when I was using the blue screen set, so I wouldn't mind seeing that added. Would be nice to specify a max probe travel distance in all directions.
    Just my 2 cents.
  17. #137
    Mar 2003
    35494
    Yes, exactly.
    Any other feedback is extremely welcome. I probably won't use this at all myself, so I'd like to make it useful for as many people as possible.
    Gerry
  18. #138
    Feb 2009
    1290
    I will switch to your screens Gerry, if the edge finding routines are working?
    You have helped me on more than one occasion, it looks like you have put some time and effort into these screens.
  19. #139
    Mar 2003
    35494
    It might be a few weeks until I get them working. I anticipate making a lot of changes as they develop.
    Gerry
  20. #140
    Mar 2003
    35494
    I think I'm going with this.
    Gerry
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
