603,349 active members*
3,603 visitors online*
    Aug 2019
    Question mach3 Digital Read Out Jumping/Bouncing
    So ive just changed over my break out board for something that supported slave with additional axis and im have everything working moving etc hooked up ready to go.
    But my digital readouts are bouncing / flickering as such when drivers and machine are at idle/ not moving.
    This is obviously causing issues with ref homering, as the change in values is locking the endstops as it thinks machine has past the limit.
    Is this a grounding issue?
    Regards
    Jun 2005
    1791
    Re: mach3 Digital Read Out Jumping/Bouncing
    Sounds like an EMI noise issue. Does it do it worse when the spindle is running?
    I have been experiencing the same problem. Three different PC's, WinXP and Win 10, Four different USB cables and three different models of Novusun motion controllers. The jitter/jumping/bouncing DRO issue arose after the axis had been homed, without homing it didn't occur. Even when the 24V power was removed from the motion controller, and no power to the PSU's and drivers, it remained. The motion controller then only being powered by the USB cable
    The problem was with Mach3 V3.043.062. I replaced it with Version 2.063 and the problem disappeared. I have yet to try it with earlier versions of V3.043
    - - - Updated - - -
  1. question about Digital read outs
    By mamech in forum Uncategorised MetalWorking Machines
    Last Post: 04-24-2016, 01:58 PM
  2. x2 mill. digital read outs jumping around
    By brendan_h in forum Benchtop Machines
    Last Post: 03-23-2014, 12:16 AM
  3. DIY DRO (digital read out)
    By rlwoodjr in forum Open Source Controller Boards
    Last Post: 01-16-2012, 05:29 AM
  4. Laser triangulation for digital read out???
    By jduke in forum Benchtop Machines
    Last Post: 04-11-2011, 09:11 PM
  5. A Digital read out ? on our BenchMills
    By Arich0908 in forum Benchtop Machines
    Last Post: 04-28-2010, 05:18 PM
