603,407 active members*
2,125 visitors online*
    Jul 2009
    140
    Mach3 + SmoothStepper + G540 = No go
    I've just completed my first router, and am beginning testing of the unit.
    I've not set up home or limit switches; merely bridged the limit switch connections to simulate the "NC" state of each switch.
    I've got the G540 Mach 3 XML file loaded.
    I can use the jog functions; both keyboard and the GUI arrows that come up when you hit "tab". The unit jogs just fine this way.
    I see a common question is, "do the steppers lock up when the program starts" - yes!
    When I do the circle wizard, I can post the G-code and a toolpath is generated. Back to the main screen, I can hit Cycle Start, the steppers unlock (I think?) and after a few seconds, an error comes up saying "The Smoothstepper ran out of data" and such and such.
    I should also note that I'm running the demo version of Mach3, as I want to verify that the thing works before I drop (more) money on this project of mine.
    Thanks in advance for the help!
    Kevin
    Mar 2003
    35494
    Never used a Smoothstepper, but from what I've read, you may be getting interference on the USB, and/or losing connection to the Smoothstepper.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2004
    73
    Turn off the USB "Power Saver" function
    I had basically the same issue. I turned down the data stream speed in SmoothStepper config to 1KHz (don't remember it's actual name but it's th etop left-hand window in the SmoothStepper config menu (PlugIn menu bar)) and turned off the USB power saver function in the Device Manager (Control Panel/System/Device Manager/USB Port Hub controller (all of them)/Properties/Power Management). Cleared up my "Timeout error retrieving data" and the "SmoothStepper ran out of data" issues.
  1. G540 E-stop and Mach3
    By Astroguy in forum Gecko Drives
    Last Post: 02-03-2012, 05:10 AM
  2. G540 and SmoothStepper
    By Nzoldun in forum Gecko Drives
    Last Post: 07-31-2010, 05:22 PM
  3. G540 and Smoothstepper
    By escott76 in forum Benchtop Machines
    Last Post: 08-28-2009, 08:24 PM
  4. G540 Mach3 XML File
    By CoAMarcus in forum Gecko Drives
    Last Post: 11-08-2008, 06:38 AM
  5. SmoothStepper and Mach3 setup
    By jeffmorris in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2008, 09:09 PM
