603,826 active members*
3,518 visitors online*
    Post Mach3 Support and Customization
    Hello Guys, Greetings.
    I am a total beginner with mach3. My application needs a motion control system 3 axes with an ink printer head installed instead of cnc_tool or material head. I want to print on rolling fabric. For printing, we need specific coordinates on the fabric on which text is to be printed. I need some following information if you wouldn't mind answering.
    I want to use the mach3 Modbus communication and customization functions to achieve the following things. I would really appreciate if experts can help me in this regard.
    1)First of all, do I need to create a CAD file to generate gcode for specific coordinates on which text is to be printed? software for fabric is Gerber etc.
    2)Now moving to coordinates is a motion controller task right? the main enigma here is that when gantry moves to a specified location, a trigger or command is needed for the printhead (INk printhead which is separately controlled by its own controller) to print the text. How to give this command? I want to use Modbus communication with mach3? Remember! The ink printhead has its own controller separately controlled by its own software.
    3)When a command is given to printhead. How to automate gcode so that when it reaches the certain coordinates it should stop for a while, send the trigger to the printhead, and printhead pick the specific text string to be printed on specific coordinates? How this can be achieved? I mean where will the text file be placed and gcode file? how mach3 will know that on specific coordinates I need to send the command to the printhead to print the only specific text.
    4) Does this mach3 fulfill the functionality I want to achieve? Am I in the right direction.
    if you need any further information I shall be happy to provide it. Your prompt response shall be appreciated.
    Martin Alley,
    Ontario, Canada.
    May 2006
    4090
    Re: Mach3 Support and Customization
    Hi Martin,
    Do you have or intend to use a KFLOP?
    If so, you might consider using our free KMotionCNC software.
    TK
    http://dynomotion.com
  1. Which CAM software for 4 axis and mach3 support ?
    By greg2fs in forum Uncategorised CAM Discussion
    Last Post: 04-18-2014, 02:55 PM
  2. Does anyone offer phone support for Mach3?
    By NardisAmps in forum Mach Software (ArtSoft software)
    Last Post: 12-09-2013, 12:51 AM
  3. USB support for Mach3
    By ger21 in forum Machines running Mach Software
    Last Post: 08-24-2013, 11:50 AM
  4. One more CNC pendant for Mach3. With Ethernet support.
    By Alexey Vorobyev in forum Mach Wizards, Macros, & Addons
    Last Post: 08-09-2012, 12:20 PM
  5. Does Mach3 support an IF or GOTO commands?
    By alank2 in forum Mach Software (ArtSoft software)
    Last Post: 04-25-2012, 12:44 AM
