603,864 active members*
4,512 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Machine Definition
Results 1 to 5 of 5
    Jul 2011
    Machine Definition
    Having some trouble saving edits to my Machine Definition in the Manager! I make the edits and hit the save button and then OK. Then if I go back in to the Manager it has saved over my Machine Def with the Default. Try to do a save as as well to try to create a copy with the edits, same thing happens.
    dherberger
    Jun 2009
    65
    Do a search for this over on emastercam dot com.
    Jul 2011
    Thanks I will give it a look!
    Aug 2005
    10
    Select machine type as design. Open a new file so no machine is active. Go to machine definition manager open you machine definition make changes and save. If you open a file that has been programmed before go to files and reselect your machine file. Works fine for me this way. I think it is just a little quirk with Mastercam.
    Jul 2011
    Hey Thanks I will give that a try!
  1. TL-2 machine definition for Mastercam
    By jefffalk in forum Haas Lathes
    Last Post: 07-26-2017, 10:37 AM
  2. FLA 100 Machine definition
    By Justin Cavender in forum DIY CNC Router Table Machines
    Last Post: 02-13-2011, 08:54 PM
  3. Machine Definition help
    By drupillow in forum Mastercam
    Last Post: 04-24-2010, 12:04 AM
  4. Machine Definition setup
    By jimmy996 in forum Mastercam
    Last Post: 03-25-2010, 04:12 AM
  5. Machine Definition
    By rrbmachining in forum CamWorks
    Last Post: 02-21-2009, 12:04 AM
