587,611 active members*
4,543 visitors online*
IndustryArena Forum > CAM Software > UG NX > Machine "window frame" method ? Please help !
Results 1 to 4 of 4
    Nov 2005
    35
    Hi everyone,
    As a newbie, I read NX workbook for manufacturing, the instruction is not clear enough to me... I try to machine the part by use method "window frame" Can everyone give me a info, tutorial or video ? Thanks
    P.S. Do you guys know any websites for UG NX CAM tutorial ? Thank a lot
    Attachment 189902
    Feb 2006
    146
    Looks like you need to add some geometry to represent the tabs that are left holding the part in the stock.
    Online Self-Paced Training for Engineers - i GET IT has several cam courses, no it is not free.
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    Aug 2008
    71
    One of our out of the box tutorials uses this technique.
    Help --> Manufacturing Tutorials, anbd pick the 6th one - 5-axis Bulkhead Machining.
    Mark Rief
    Siemens PLM
    Nov 2005
    35
  1. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. 24"X, 18"Y, 3"Z Steel Frame Desktop Machine
    By TLHarrell in forum DIY CNC Router Table Machines
    Last Post: 06-16-2009, 06:33 AM
  4. Replies: 24
    Last Post: 03-26-2009, 07:43 PM
  5. "best" method for fixing together mating tubes?
    By RoGuE_StreaK in forum Mechanical Calculations/Engineering Design
    Last Post: 06-29-2008, 12:20 PM
