603,890 active members*
2,708 visitors online*
Results 1 to 4 of 4
    May 2017
    40
    Matched angular contact bearings
    I'm looking for another matched pair of angular contact bearings.
    I was able to find a pair of matched NSK's and they allowed me to get the total error on the X axis of my mill down to 0.0003", and I'm happy with that goal was < 0.001"
    Now I need another set for another axis and found these old stock on ebay. They appear to be a matched set (same box), but I'm not sure they might just be two unmatched. I asked the seller and he has no clue. I tried to find details online but no luck.
    Does anyone have any insight?
    https://www.ebay.ca/itm/296398607476
    Nov 2013
    5408
    Re: Matched angular contact bearings
    I suspect they are matched, but I suspect not universally. The part number concluded DUL which I think means Face-Face. Universally matched bearings can be used DF, DB or DT.
    Craig
    May 2017
    40
    Thanks for that, I found another pair, that are matched for sure. Basically the same as what I used previously, except the cage type (Y vs. R)
    On order.
    https://www.ebay.ca/itm/385567495647...Bk9SR9ab_O_0Yw
    Mar 2025
    11
    I think you need to determine what the contact angle is. NSK has 3 types, 15, 25, and 30 degrees. Here are detailed dimensions for these three types of bearing, and they are all universal matching bearing.
    https://www.coolenbearings.com/nsk/s.../7001ctynsulp4 7001CTYNSULP4 15 degrees
    https://www.coolenbearings.com/nsk/s...7001a5tynsulp4 7001A5TYNSULP4 25 degrees
    https://www.coolenbearings.com/nsk/s.../7001atynsulp4 7001ATYNSULP4 30 degrees
  1. FAG vs. No-Name Angular Contact Bearings
    By JukeBox in forum Linear and Rotary Motion
    Last Post: 01-01-2016, 06:59 PM
  2. Angular Contact Bearings
    By Anita in forum Linear and Rotary Motion
    Last Post: 10-28-2012, 03:17 PM
  3. angular contact bearings, or not
    By klick0 in forum Linear and Rotary Motion
    Last Post: 04-12-2012, 04:49 AM
  4. why angular contact bearings for X3?
    By lagfish in forum Benchtop Machines
    Last Post: 01-09-2008, 12:12 AM
  5. Angular contact bearings
    By martinw in forum Mechanical Calculations/Engineering Design
    Last Post: 12-26-2006, 01:35 PM
