603,311 active members*
2,009 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions
IndustryArena Forum: Material Machining Solutions
Page 10 of 36 8910111220
Threads 181 to 200 of 715
Discuss general material machining problems and solutions here.
  1. Knurling 2-3mm Al wire?
    Started by Teledog, 05-09-2014 09:22 PM
    08-21-2014, 05:03 AM Go to last post
  2. Oak edges blowing out
    Started by john@tlt, 08-12-2014 04:59 PM
    08-12-2014, 04:59 PM Go to last post
    08-11-2014, 12:53 AM Go to last post
  3. 304 Stainless 0.1250 Thickness
    Started by Robert-I, 08-04-2014 11:43 PM
    08-06-2014, 06:41 AM Go to last post
  4. Can't cure chatter - machining long shaft on lathe
    Started by sabine, 07-26-2014 12:34 AM
    also, bar, bridgeport, carbide, chuck, copper, cutting, final, finish, headstock, holding, hot, lathe, machining, metal, offset, pass, problem, reset, screw, settings, shaft, soft jaws, steel, stock
    07-27-2014, 11:00 PM Go to last post
  5. Question on Foam
    Started by Rickyg, 06-18-2014 03:30 AM
    07-21-2014, 06:17 AM Go to last post
  6. Arbro Plate
    Started by jack-pat, 07-19-2014 11:53 AM
    appreciated, arbro, back, bee, clamps, comparison, cut, edges, en24t, flame, grade, hard, heard, machinable, make, needed, plate, profile, steel, supplier, will, wondering
    07-19-2014, 03:22 PM Go to last post
  7. Need help for my Puma 2000sy
    Started by CharlesPayette0, 07-07-2014 05:27 PM
    000, 0000, 200, 2000sy, ant, bat, battery, change, color, good, important, ion, need help, position, puma, recently, seco, tha, turret, vol, volts
    07-07-2014, 05:27 PM Go to last post
    07-03-2014, 05:38 AM Go to last post
  8. Want rust finish on forging
    Started by Ted383, 02-01-2013 04:42 PM
    06-19-2014, 07:53 AM Go to last post
    06-18-2014, 04:47 AM Go to last post
  9. Drilling 303 Stainless Steel
    Started by Dichotomy, 06-06-2014 08:26 PM
    drill, drilling, feed, peck, thing
    06-06-2014, 11:30 PM Go to last post
  10. parting off 316ss?
    Started by Ray 2x, 05-28-2014 07:16 AM
    2000, bar, chamfer, change, chester, cut, endmill, feed, finish, input, machine, mori, mori seiki, part off, parts, post, problems, questions, seiki, speed, stainless, stock, tag, tools, turning
    06-01-2014, 02:56 PM Go to last post
  11. Titanium grade 5
    Started by mattlynx, 05-25-2014 10:27 AM
    iphone, mode, rigid, rigid tapping, rpm, run, running, tap, tapatalk, tapping, titanium, vertical
    05-27-2014, 11:30 AM Go to last post
  12. Wich material for pretty low cost gears ?
    Started by bokan, 05-15-2014 09:42 PM
    1000, cheap, co2, co2 laser, cut, cutter, cutting, demo, force, glass, ice, inside, laser, laser cut, laser cutter, material, nice, parts, plastic, plexiglass, post, power, price, question, routing
    05-15-2014, 09:42 PM Go to last post
    05-11-2014, 05:14 AM Go to last post
  13. machining ceramics
    Started by steve pies, 04-26-2014 04:51 PM
    carbide, ceramic, diamond, fiber, find, glass, machined, machines, machining, materials, nickel, optic, plastic, resin, shop, stone, tooling, wheels, works
    04-26-2014, 04:51 PM Go to last post
    04-14-2014, 03:45 PM Go to last post
  14. Mounting wax cylinder to 4th axis
    Started by MarcusWolschon, 03-28-2014 10:38 AM
    4th, 4th axis, axis, carving, cylinder, grip, horizontal, jaws, make, material, milling, mounting, rotating, special, wax
    04-06-2014, 07:10 AM Go to last post
  15. Drilling in PPS
    Started by graemeian, 03-15-2014 04:22 AM
    cat, cat40, center, coolant, diameter, drill, drilling, drills, high, holder, holes, ipm, line, machining, machining center, made, pcb, plastic, rpm, running, small, spindle, tool
    03-15-2014, 04:22 AM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
