587,092 active members*
5,132 visitors online*
    Jan 2013
    128
    Matsuura on Low Power Supply
    Looking at a 1996 Matsuura MC-800VF, VMC
    The only problem is the transformer on the power pole is only 25kVa (single phase) and the machine is rated 37kVa in the book specs and 41kVa, 200-220V, 118A on the metal plate on the back of the machine. The transformer was installed 1.5 years ago with a subsidy, to upgrade would mean full cost which is out of budget.
    The RPC manufactures recommend a 40hp RPC for this machine.
    Is it possible to run a smaller RPC that would work with the 25kVa transformer? Can I just run the machine at a reduced rpm/rapids/feed etc and get away with it? Can the machine/control be damaged if it goes over the available power?
    the reason I'm asking is I put some money down without checking the transformer, assuming it was sized for multiple residences, which it's not. Otherwise I would just go to a smaller machine. But this one is low hours, a good price, and has a large envelope, plus I would lose the money down.
    I'm not cutting Inconel at max rapids/feed. Mostly aluminum low volume prototyping.
    Jan 2013
    128
    Re: Matsuura on Low Power Supply
    So this leads to another question. Cart before the horse scenario.
    Working from the other direction, fitting the machine to the existing available power. With a 25kVa transformer and 200 amp residential service, what is the largest maximum RPC that you could run?
    Dec 2013
    5714
    Chris, you're correct, you have to start with the available power. That really sounds like too much machine for a residential service. The spindle HP is the controlling factor, and the RPC need to be sized to run the spindle. I have 100 amps, 240V, single phase available to my shop. So I limited the mill spindle HP to 7.5 running on single phase, and the lathe to 10 HP running on a 15HP RPC. You have to have enough power left over to run lighting, air compressor and other stuff.
    Jim Dawson
    Sandy, Oregon, USA
  1. Matsuura MC 760 VX Power Issue
    By Jagath0n in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2021, 03:53 AM
  2. Replies: 1
    Last Post: 01-12-2017, 07:12 AM
  3. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
