587,259 active members*
3,063 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Mazak M32 will send to usb but wont recieve
    Nov 2016
    7
    Hey I'm really hoping that someone here can help me out a little bit. I have a mazak M32 control on an H1000. We have Calmotion USB to CNC boxes to transfer our programs to our machines. I am having issues uploading programs. We are using the correct port. Attached is our current wiring diagram for the rj45 to db25 adapter. The machine will send programs from the control to the usb but doesn't seem to take any programs at all.
    Heres some of my machine parameters
    M32
    G1 = 2 (4800 baud for CMT I/O, use CMT DB25 port)
    G19 = 2 (4800 baud for TAPE I/O, use PTR/PTP port)
    G20 = 3 (2 stop bits)
    G21 = 0 (Even parity)
    G22 = 0 (Invalidate parity, disable parity check)
    G23 = 3 (8 data bits, includes parity in data)
    G27 = 0 (CR/LF)
    G29 = 3 (DC1 to DC4 which means XON/XOFF)
    G30 = 1 (Assignment of parity to DC codes)
    G40 = 0 (No DC2/DC4 is output)
    G41 = 0 (No leader)
    G42 = 600 (60 second wait)
    G43 = 00000000 (ISO)
    G44 = 0 (No spaces before tape)
    G45 = 0 (No spaces between programs)
    G48 = 0 (Disable rewind)
    G49 = 1 (Load All enabled)
    G50 = 00000000 (don't use M02, M30, M99 as end of program)
    Oct 2016
    30
    Re: Mazak M32 will send to usb but wont recieve
    Quote Originally Posted by dlewis1000 View Post
    M32
    G27 = 0 (CR/LF)
    G41 = 0 (No leader)
    ERROR IN YOUR PROGRAM,
    Remove the program and install it again.
    This helps in most cases.
    Nov 2016
    7
    Quote Originally Posted by timgo View Post
    Not sure how it could be an error in the program. If the machine can send a file onto a usb stick why cant I take the same file and stick it back on the machine? The machine exports the programs as .txt files on our usb box. The machine wont take any programs at all even if they originally came out of the control itself. I tried making a program on the control, sending it to the usb stick, and back to the machine with no luck. Made sure my programs have the % sign at the start and end. They also all have a correct program number and ending code. Attached is a diagram of our rj45 to db25 adapter or pin-out. Attachment 338356
  1. Replies: 5
    Last Post: 06-01-2014, 05:02 PM
  2. M2 Control send/recieve parameters via RS-232?
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2012, 02:07 AM
  3. Replies: 5
    Last Post: 12-13-2010, 05:25 AM
  4. Fanuc 0-M RS232 can recieve but not send
    By malaron in forum Fanuc
    Last Post: 10-01-2007, 04:02 PM
  5. PC wont send to Mazak
    By xr135 in forum DNC Problems and Solutions
    Last Post: 05-18-2006, 08:04 PM
