603,891 active members*
3,018 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mcode for Neutral spindle 520AM on Mighty Comet??
Results 1 to 4 of 4
    Jun 2008
    24
    Anyone know the M code to put the spindle into neutral on a Mits 520AM which is on a Mighty Comet?
    The spindle is in neutral when the machine is started, but once it goes into high, or low, "gear" with an "S" command, I can't figure out how to return it to neutral when I try to indicate a hole position.
    Dave
    Jun 2010
    14
    Try M40.
    Often on a turning center with a 2-speed gearbox: M40 is neutral, M41 is low gear, M42 is high gear.
    Jun 2008
    24
    Thanks ..... I'll try this tomorrow when I get back to the shop..
    Dave
    Jun 2008
    24
    well ...... M40,41,and 42 don't do anything.......
    Dave
  1. Setting up Mighty Comet 1000 VMC
    By rogerindigo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-31-2014, 02:31 PM
  2. Mighty Comet vmc500-p
    By Gpl625 in forum MetalWork Discussion
    Last Post: 04-12-2012, 08:01 AM
  3. Mighty comet parameters VMC-750 needed/Spindle problem
    By Petro in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-30-2010, 04:27 PM
  4. MIGHTY COMET MIDAS 320 CONTROLL
    By joshuasalens in forum DNC Problems and Solutions
    Last Post: 07-30-2009, 01:18 AM
  5. Mighty Comet with Meldas M0
    By Bert10 in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2008, 11:35 PM
