587,155 active members*
5,151 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > MDF protection from moisture / humidity
Results 1 to 4 of 4
    Jan 2009
    7
    Question MDF protection from moisture / humidity
    I'm starting a first time build and haven't worked with MDF much. I was wondering what has been found to work best for protecting MDF from moisture and humidity. I have to keep mine in the garage and it can get a bit damp out there from time to time with the changin temp.'s.
    thanks for your opinions
    Jun 2005
    1730
    Paint or put poly on all the parts after you machine them. Moisture in a garage environment will impact them overtime. MDF is pretty stable stuff but it is very absorbant so if you coat all the side it will stay true. Remember when you buy the stuff from a home improvement store they keep it in their building which is heated or air conditioned depending on the season. The key thing is it is kept dry.
    CNCMAN
    Mar 2003
    35538
    You can also coat it with a thin epoxy like West Systems, followed by paint.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2009
    7
    Thanks for the suggestions!! Well hopefully I'll get a design figured out soon and have I on the go.
  1. Effects of moisture on plasma cut???
    By Jcar in forum Waterjet General Topics
    Last Post: 02-23-2009, 11:48 PM
  2. Connection with Humidity sensor (4-20ma) and PLC or temperature controller
    By rainman in forum CNC Machine Related Electronics
    Last Post: 09-13-2008, 12:55 AM
  3. It's not the heat, it's the humidity
    By qroger in forum Environmental / Alternate Energy
    Last Post: 07-12-2007, 02:30 PM
  4. How to rid moisture in sandblast media
    By tmt_92021 in forum Mass finishing equipment/media/strategies
    Last Post: 08-05-2006, 07:12 PM
