603,996 active members*
3,464 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion
IndustryArena Forum: MetalWork Discussion
Page 9 of 336 78910111959109
Threads 161 to 180 of 6703
Discuss general metalwork problems, tips and techniques for machining metal.
  1. Sticky Thread Sticky: Share Your Files Part or Art
    Started by lakeside, 04-07-2006 02:55 PM
    587 Pages
    1 2 3 4 5 ... 587
    06-27-2025, 06:12 AM Go to last post
  1. cut acrylic on a milling cutter or on a laser?
    Started by TomJacks0n, 05-27-2022 01:02 PM
    06-25-2022, 01:36 AM Go to last post
  2. Qualichem Q-Cut 215
    Started by MADMATT1964, 06-16-2022 06:43 PM
    appreciated, feedback, q-cut, qualichem, switching
    06-16-2022, 06:43 PM Go to last post
  3. Smile Learn Chinese and exchange CNC
    Started by LESSING, 06-12-2022 02:50 AM
    chinese,cnc
    06-12-2022, 02:09 PM Go to last post
  4. Do RPM's matter when cutting on a lathe?
    Started by MychesterCNC, 05-26-2010 07:44 PM
    down, far, since
    06-08-2022, 02:51 PM Go to last post
  5. Cutting Aluminum Sheets.
    Started by GeorgeDaWorge, 05-26-2022 01:44 AM
    aluminum, cnc, cut, passes, table
    06-04-2022, 05:45 AM Go to last post
    05-12-2022, 07:14 PM Go to last post
  6. SS Break Nuts production
    Started by roopeshvakharia, 05-12-2022 01:28 PM
    05-12-2022, 01:28 PM Go to last post
  7. Deep Drilling Aluminum
    Started by Rex Smith, 04-20-2022 05:40 PM
    04-21-2022, 07:53 AM Go to last post
  8. Step down shank weaken a carbide bit?
    Started by YakkoWakkoDot, 04-16-2022 05:31 AM
    aluminum, bit, inches, step, wondering
    04-19-2022, 03:41 AM Go to last post
  9. rotary table automatic indexing
    Started by dz1, 02-05-2015 11:40 AM
    04-14-2022, 05:02 PM Go to last post
    04-12-2022, 04:46 PM Go to last post
  10. CNC Router Type High-Z/T
    Started by Tzamba, 04-03-2022 05:39 PM
    called, cnc, high-z/t, router, type
    04-03-2022, 05:39 PM Go to last post
  11. ID Workholding question
    Started by rlivergood, 02-16-2022 07:38 PM
    04-02-2022, 02:32 PM Go to last post
  12. Designing an M48 0.75 Tap
    Started by nateman_doo, 11-24-2021 06:44 AM
    04-02-2022, 06:16 AM Go to last post
  13. 6082-T6 aluminum cutting with air blast only?
    Started by sploo, 03-23-2022 01:49 PM
    air, aluminum, chips, cnc, cooling
    03-24-2022, 10:29 AM Go to last post
  14. Question Picking out equipment for hobby.
    Started by AnotherCNCNewbie, 03-17-2022 04:42 AM
    low, putter, putters, stainless, steel
    03-22-2022, 03:37 PM Go to last post
    03-15-2022, 05:03 PM Go to last post
  15. Post Impeller Machining
    Started by Manishpwn, 03-14-2022 06:33 AM
    cutting tool, impeller
    03-14-2022, 06:33 AM Go to last post
  16. Low cost measurement of hardness?
    Started by Jim27, 03-12-2022 04:23 PM
    cost, file, hardness, indent, low
    03-12-2022, 09:58 PM Go to last post
  17. Asking for Help Re: Feeds and Speeds for 4140/4150
    Started by JGod76, 03-11-2022 05:51 PM
    03-11-2022, 05:51 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 99 users browsing this forum. (0 members & 99 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
