603,310 active members*
2,330 visitors online*
    Aug 2005
    302
    Milling an oddball thread
    I have a Tormach PCNC 1100 with 4th axis . I am not sure what numbers to put in the A ______ and in The F______ . The X is the distance traveled in X.
    If someone can give me an explanation as to what actually is needed and how to get there I would grateful .
    Thanks ,
    ErnieD
    Oct 2024
    6
    Re: Milling an oddball thread
    if you're rotating the part by 90 degrees and want the machine to move at 10 degrees per second, you’d enter A90 and F600 (since 10 degrees per second translates to 600 degrees per minute).
  1. Making an oddball Homag spindle useable?
    By Tristar500 in forum MetalWork Discussion
    Last Post: 03-01-2021, 10:30 PM
  2. Converting a Sherline Mill to Mach3 with oddball drivers.
    By ruckusnuts in forum Stepper Motors / Drives
    Last Post: 11-22-2019, 06:12 PM
  3. Thread milling a 1/8-27 npt internal thread
    By Slick27 in forum BobCad-Cam
    Last Post: 02-17-2016, 07:58 AM
  4. Oddball stepper question - auto-focuser
    By Rhodan in forum CNC Machine Related Electronics
    Last Post: 11-11-2009, 09:07 PM
  5. Thread Milling
    By Doubleddaved in forum Haas Mills
    Last Post: 09-12-2009, 03:05 PM
