603,907 active members*
4,733 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Mini Lathe restoration / tuning advice?
Results 1 to 12 of 12
    Jun 2008
    31
    Just bought a used harbor freight 7x10 mini lathe for $200.
    I'd like some advice on restoring/tuning to like new or better than new condition.
    Aug 2009
    899
    I would follow this guide as if the machine were new as it is to you. http://www.mini-lathe.com/Mini_lathe/Setup/setup.htm
    In other words take everything apart, clean everything, lube everything put it back together.
    This page will show you how to adjust the Lathe
    http://www.mini-lathe.com/Mini_lathe/Tuning/tuning.htm
    Have fun and don't be afraid to ask any questions.
    Jun 2008
    31
    Thanks! ... that hit the nail on the head!
    Mar 2008
    3655
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Jul 2007
    1602
    There is a lot of good information here: http://www.arceurotrade.co.uk/projects.aspx
    In particular, the "C3 Mini-Lathe Preparation Guide" is really good.
    bob
    Jun 2008
    31
    Wow... All those links really cover the topic nicely!
    It looks like I'll be doing a full dis-assembly of my mini lathe.
    THANKS!
    Feb 2010
    Varmit Al has some interesting mods and info on his site. It's linked on the mini-lathe.com site. If you have some way to cut brass gibs, that sure smoothed up my cross slide. Good luck with your rebuild!
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
    Mar 2004
    1306
    There are dozens of mods which improve the 7x:
    http://www.homemodelenginemachinist....p?topic=7893.0
    My favourites:
    - T slot cross slide
    http://www.wrathall.com/Interests/ma...oss_slide1.htm
    - Cross slide travel increase
    http://www.wrathall.com/Interests/ma...l_increase.htm
    -Using an AXA QCTP
    - And now that I have finally done it, the tailstock lever lock mod.
    http://cnczone.com/forums/showthread.php?t=105769
    Back when mine was still a manual machine, I also added bearings to the cross slide and compound handles.
    Regards,
    Mark
    Jan 2007
    29
    I would also suggest you look at these sites:
    GadgetBuilder's MiniLathe Site
    mikesworkshop - Introduction
    Feb 2010
    Quote Originally Posted by RotarySMP View Post
    best mods for 7x10 mini lathe & mill what's yours?
    My favourites:
    wrathall.com
    wrathall.com
    -Using an AXA QCTP
    Build Thread Cam lock Tail stock for 7x12 - CNCzone.com-The Largest Machinist Community on the net!
    Mark, did you happen to save a copy of the article of the cross slide detailed by Martin Cleve? Seem gone from Yahoo group
    Mar 2004
    1306
    Yes, here it is.
    Attached Files Attached Files
    Regards,
    Mark
    Feb 2010
    Thank you very much, Mark.
  1. Mini lathe and mini mill spindle?
    By ZipSnipe in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2010, 02:13 PM
  2. Bench top/Mini Lathe & Mill advice
    By CNCMark38 in forum Benchtop Machines
    Last Post: 07-08-2010, 01:07 AM
  3. Enco 9 x 20 Lathe Restoration
    By warossignol in forum Mini Lathe
    Last Post: 04-03-2008, 08:40 PM
  4. X2 Mini Mill & Mini Lathe - Cummins Tools
    By ccsparky in forum Benchtop Machines
    Last Post: 12-19-2007, 02:54 PM
  5. Need some advice on Building a Mini CNC?
    By Oldboy in forum Benchtop Machines
    Last Post: 12-01-2007, 05:34 AM
