587,178 active members*
4,450 visitors online*
Page 2 of 3 123
Results 21 to 40 of 54
  1. #21
    Nov 2008
    6
    DEAR ALL
    WHAT ABOUT THE VOLTAGE AND CURRENT FOR EDM MACHINE
    THANKS IN ADVANCE
    GAMAL
  2. #22
    Sep 2006
    13
    I am looking into purchasing a Mitsubishi FA10S Wire edm. Can anyone give me any input into the machine?
    What does the FA (vs FX) mean? Also the "S"
    Am going to be cutting Titanium. Would it be a good machine?
  3. #23
    Jun 2008
    10
    Hello does somebody know where can I found a use board or repair the FW-01 board for a Wire EDM Mitsubishi DWC 90 CR
  4. #24
    Dec 2009
    18
    I have mitsubishi EDM DWC-90H could anybody help me.It work very good before i change its batteries because they completely dead. Now when i turn the machine on no alarm appears tape load perfectly. But after that the system ready button do not activate.I see the system parameter it appears to be correct ( I do not know the right value) but optional parameter no.1 and no.2 do not show any thing they are blank. I think there parameter become corrupted. Could anyone help me to solve this problem.
  5. #25
    Sep 2008
    16
    WEDM
    Have you try reloading the software?
    Sometimes when you change the batteries you miss some parameters...
  6. #26
    Dec 2009
    18
    Hi roswell28
    yes, I think too that after changing the batteries I have lost parameter. I have tried many times to reload system. usually i use three tapes. One is erase, second is system 1 and third is system 2. fifth is e-pack. I do not know why there is not a fourth tape.did i missed the fourth tape.do you have dwc-90h. could you please tell me the parameters of system paramter.
  7. #27
    Sep 2008
    16
    Software loading
    Hi Buddy.
    I have just 3 floppy disk, one is for E-Packs,other for Pitch Error and the last one have the version of the software of the machine (It could be D1 or E4).
    Do you have the same disks? Do you have the right procedure to reload the software?
    If you need more help please let me know.
  8. #28
    Dec 2009
    18
    Quote Originally Posted by Roswell28 View Post
    Hi Buddy.
    HI!
    I have four cassettes. As i have already told you that one is for erase and other two are for system load. One is for e-pack.I do not know where to find the machine software version? do you have dwc-90h? could you please send me the picture of your system parameter screen? I highly appreciate if you can.
  9. #29
    Feb 2010
    hi all
    ı have mitsubishi fx30k 2000 model.how ı can found e pack and offset for 0.25 wire latest version? thanks
  10. #30
    Jan 2009
    64
    See attached: hopefully this is enough to get you going.
    Tech file is from FA20s
    If you get invalid epack number error then subtract 1280 from the shown epack number
    ie: 2051-1280=771 (E2051=E771) This is the epack difference between our FA and our CXs
    Hope this helps
    Attached Files Attached Files
  11. #31
    Feb 2010
    thanks Royster
    You were very helpful in
  12. #32
    May 2006
    22
    Rosweell28 >>>
    I have a 110HA model, maybe you could help me.
    i have the T215 code alarm, that says: "SECUENCE ERROR"
    this alarm becomes after a 10 min. aprox. working time , i re-start you know:
    FLUID > WIRE > MACHINING > START
    it works again about 3 min. and T215
    again and again
    HELP !
  13. #33
    Sep 2006
    13
    We have a '98 FX10.
    On our machine the T215 error seems to be a generic error message. If you can be looking very carefully at the screen when the meesage comes on, it will very quickly flash a more specific error & then change to T215.
    That being said, I asked my dept forman about your issue. He said that they had a similar problem & it was simply the water level. The first time was when we just got the machine & the tech who set it up had only partially filled the holding tank, after a couple of weeks, the water evaporated a little & when we filled the tank, the water in the holding tank dropped below the sensor.
    My forman suggested checking water level, fiilters & perhaps clean the sensor in the tank.
    Good Luck
  14. #34
    Oct 2011
    Hello , I have four cassettes for FX30K. Are you still interested ?
    cassette 1 BRD-B00W005A1 (1/3)
    cassette 2 BRD-B00W005A1 (2/3)
    cassette 3 BRD-B00W005A1 (3/3)
    cassette 4 BRD-B19W050-A3 WEDM SYSTEM PROGRAM INGLISH
    cassette 5 BRD-B93W364-A0 DATA I/O
    cassette 6 PITCH ERROR AND BACK LASH
    cassette 7 BRD-B13W019-A6 E-PACK
  15. #35
    Apr 2009
    6
    can fine my way home
    hello.......need some help with mi fx10wire i cant communicate with it,im using cimco edit with thes setings:
    com1 stopbit 2 even
    baudrate 2400 databit 7
    sofware
    am i way off...i need some help ,im new at thes and i realy dont have a clue.
    ill buy you a beer
  16. #36
    Feb 2009
    51
    The settings we use for our computer are as follows:
    Com 1 (this is the com port that you have the cable plugged into on your computer)
    2400 Baud rate
    even parity
    7 databits
    1 stop bit
    if you cannot get the machine to receive with these settings you may have to reduce the baud rate, but you have to then alter the machines baud on machining data, RS para page.
  17. #37
    Apr 2009
    6
    thanks for the tip .................you were wery helpful.....
    god speed
  18. #38
    Mar 2013
    Dear guys,
    In our company we bought machine Mitsubishi FX10 wire edm. We have problem when we turn on machine, on screen you can see System reload message.
    Machine was before electrity maybe 7 days. Machine now ask me to put system floppy disk. My question is If somebody have floppy disks for this machine?? Thank you in advance
  19. #39
    Feb 2009
    51
    Do you have an FX10 or FX10K?
  20. #40
    Mar 2013
    FX10 We have
Page 2 of 3 123
  1. Wire EDM Mitsubishi DWC-200 H1
    By Roswell28 in forum Waterjet General Topics
    Last Post: 03-10-2014, 05:44 PM
  2. "WIRE BREAKAGE" alarm on Mitsubishi Wire DWC90HA
    By GEC-ENG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2013, 01:21 PM
  3. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum EDM Discussion General Topics
    Last Post: 01-26-2011, 10:47 AM
  4. Mitsubishi wire type setting for zinc coated wire
    Last Post: 01-25-2011, 01:49 PM
  5. Mitsubishi FX1 Wire
    By one4design in forum EDM Discussion General Topics
    Last Post: 10-05-2008, 07:37 PM
