I am trying to turn on the coolant functions in my post for Alphacam 2014 r2 standard router.
In my post the coolant section is short and doesn't show the M codes. I have a generic 3 axis post that has the block of code I need. (below)
$----------------------- COOLANT OFF/MIST/FLOOD/TOOL CODES ------------------
Codes in $150 to $153 are assigned to CLT as required for each path
$150 Code to Turn Coolant OFF
M09
$151 Code to apply MIST Coolant
M07
$152 Code to apply FLOOD Coolant
M08
$153 Code to apply THROUGH TOOL Coolant
M10
I made a copy of my working post and copied the block into, but it still didn't work.
The problem is, it's called with a CLT from higher in the post. In the generic post, it is called from the rapids xy section and in the drill cycles.
The Rapid XY section in my working post is radically different, (and I don't have any drill cycles). I don't know what effect it will have to monkey with it.
Any suggestions? Thanks!
