587,890 active members*
3,358 visitors online*
    Jun 2007
    44
    Mori NV5000 window glass cleaning
    Hi
    we have 12 Mori NV5000 with operator's sliding door has window (glass). They are all yellowish (caused by coolant) and can't clean them, stuck on glass. Tried windex, and other cleaners, didn't work. Operators are complaining abot not being able to see. How can I clean or get rid of dried coolant stuffs.
    Feb 2009
    6028
    If alchohol wont clean them,Time to get new windows. Mori has specs on window life, think after 5 years the windows degrade to 50 percent of impact resistance. They have put a lot of time and money in to studying guarding and windows. The new machines even have timers to alert you. Mori probably has the best safety windows on the market btw, it started with a guy getting hurt real bad, he's in a comma still after 15 years. Owner of the shop had lexan cut and made his own window on a old sl. It was a huge mess for everyone.
    Dec 2008
    4
    NV window cleaning
    I use simple green or WD 40 and a Scotch brite pad. since the inside is glass it does not scratch. I scrub with my hand not power tools. It does take some elbow grease, but it usually works.
  1. Mori NV5000 Z-axis ref. adjustment
    By teal854t in forum Mori Seiki Mills
    Last Post: 11-01-2022, 12:03 PM
  2. Need Help on Mori Seiki NV5000
    By dannifer.ebot in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2010, 07:45 PM
  3. Mori NV5000, program directory (available memory)
    Last Post: 07-31-2009, 02:57 PM
  4. G08 on mori NV5000
    By Mill Guy in forum Mori Seiki Mills
    Last Post: 10-25-2008, 12:02 AM
  5. Mori NV5000 lost X,Y,Z,W zero reference
    By teal854t in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2007, 02:34 PM
