587,947 active members*
3,333 visitors online*
Results 1 to 4 of 4
    Aug 2004
    309
    Mori Seiki sl1 threading question
    does the Mori Seiki SL1 support rigid tapping?
    Oct 2007
    74
    No, I don't believe it does. I am pretty sure it uses an belt driven encoder to track the spindle speed and this in not accurate enough to use to be able to sync the spindle to the axis to allow for rigid tapping.
    jp
    Aug 2004
    309
    much thanks, one other question about the SL1 , is it cabaple of thread turning? Looking at a used machine
    May 2007
    51
    Yes, no problem.
    The SL1-a in our shop uses this syntax:
    G76P010055
    G76X-11.34Z-9.3R0P810Q300F1.337
  1. Replies: 11
    Last Post: 07-16-2022, 12:13 AM
  2. mori seiki?
    By manuelc149 in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2007, 12:15 AM
  3. Threading problem on Mori seiki zl-15smc
    By DryRun in forum G-Code Programing
    Last Post: 09-19-2007, 05:57 PM
  4. Mori Seiki SL-204
    By dcworld in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2007, 04:25 AM
