587,543 active members*
6,074 visitors online*
Results 1 to 4 of 4
    Aug 2014
    Mori Seiki SL1A LX1 330, 310 Errors
    I have had this machine for about 7 years and has been a bullet proof machine thus far. But the other day I went to start it up to do a few job's on it and when I went to hit the start button the second time the machine didn't start and continued to say the 330 Emergency Stop and 310 Servo Off Errors. This machine is a 1983 Mori Seiki SL1A with a Yasnac LX1 controller on it. I have tried everything that I have thought of from checking overtravel-limit switches to checking the emergency stop switch. All seems to be fine. I just need someone that might know what else I can check.
    You need to trace out the estop circuit. the 310 alarm is default because you have the 330 alarm. If the machine has a chip conveyor, dont forget that part of the circuit as well. In Addition check the following: 1305.0 Machine Ready, 1306.0.1.2.3 Over Travel Inputs, 1202.0 Estop, and 1281.1 Estop.
    The manual is available online for free at Yaskawa
    Aug 2014
    Re: Mori Seiki SL1A LX1 330, 310 Errors
    This machine does not have a chip conveyor. I'm assuming that you are meaning the diagnosis parameters
    1305.0 is 0
    1306.0.1.2.3 these are all 1
    1202.0 is 1
    1281.1 is 1
    The 1202 and 1281 don't seem to change reguardless of the estop being pressed or depressed.
    Jan 2015
    42
    I can help you but need to send you a document.
    Email me : [email protected]
  1. mori sh 630 electrical repair then errors
    By kelticwarrior in forum Mori Seiki Mills
    Last Post: 11-14-2023, 01:55 AM
  2. Trying to get Mori SL1A up and running.
    By crittenden in forum Mori Seiki lathes
    Last Post: 08-11-2013, 06:01 AM
  3. mori mv40 pg errors
    By toolwrite in forum Mori Seiki Mills
    Last Post: 09-07-2012, 03:20 PM
  4. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  5. Mori Seiki Fanuc 6M ALARM ERRORS
    By HouTX in forum Fanuc
    Last Post: 12-02-2010, 12:55 PM
