603,371 active members*
4,226 visitors online*
Results 1 to 6 of 6
    Jan 2010
    107
    Mori Seiki SL3 - Fanuc 3T parameters
    Hello
    I am thinking about buying a old mori sl3 lathe.. its without power for the last 3 months, so i suspect it have lost parameters..
    The current owner dosent have the parameters, only the manuals..
    Is it possible to find the parameters somewhere?
    Cheers
    Nov 2008
    96
    Re: Mori Seiki SL3 - Fanuc 3T parameters
    What Year is the Machine?
    Did you or he look in the back of the programing manual?
    There is a listing of the parameters. And most folks penned in the values next to the parameter listing.
    JT
    Mar 2017
    314
    Fanuc 3 used nonvolatile memory.
    Why do you think it "lost" the parameters?
    Nov 2024
    Do You have the parameters of the Mori seiki Fanuc 3t lathe ?
    Hello!
    I have an identical situation, we are trying to enter parameters from SL-1 with fanuc 3 .. we will let you know if we succeed..
    greetings djordje
    For us, the machine works with these parameters and diagnostic parameters,
    good luck DJ.
    Jul 2010
    Hello. Can you send me those parameters to [email protected] please. I wrote the parameters but an Er3 alarm appears and I cannot move the turret. The X and Z axes do move and the spindle also turns. I don't know if there are hidden parameters from 150 to 212. I don't have the information on how to write them or remove those alarms. I don't have the ladder or electrical diagram.
  1. Mori seiki sl1 fanuc 5t parameters
    By phehar in forum Mori Seiki lathes
    Last Post: 10-03-2016, 02:21 AM
  2. Mori Seiki MV45/40 Fanuc 11M parameters
    By mswcue in forum Fanuc
    Last Post: 04-24-2015, 07:19 PM
  3. mori-seiki TL1 Fanuc 6T parameters
    By shvavim in forum Mori Seiki lathes
    Last Post: 08-03-2009, 06:48 PM
