587,853 active members*
3,219 visitors online*
Results 1 to 11 of 11
    Oct 2007
    4
    Mori Seki - Fanuc 11T
    I am trying to load a program via RS232 and the controller is having a problem reading.
    I am also getting an Alarm SR820. Can anyone tell me what this alarm code means?
    Could you tell us a little more like cable config pin outs and software your using for communications I think the alarm is a DR off alarm (data set ready) I don't have a book with me but it will be in your book. Also check the port number and parameters on the machine.
    Oct 2007
    4
    We are using a basic 25-pin serial straight though. And yes it is a DR Off alarm.
    We are using Master Cam to send program via COM1 on a PCMCIA serial card.
    Not sure about the parameters in the controller.
    First you cant use a straight though cable you need a NULL modem cable or adapter if it is 25 to 25 pin you can also make your own I could give you the pin outs if your going to make it. is this a 25 to 25 no 9 pin adapter at the laptop?
    Oct 2007
    4
    Yes, it is a 25 pin to 25 pin. What would be the pinouts for this cable? I will make a cable from scratch to make sure that is not an issue.
    25 pin machine 25 pin PC
    2 to 3
    3 to 2
    4 to 5
    5 to 4 you can also jumper 4&5
    6 6,8&20 pumper at the machine
    8
    20
    if you jumper 4&5 you can't use hardware handshaking must XON/XOFF
    Also when you get your cable up try punching a program out from the machine first and tell me what you get.
    Oct 2007
    4
    I will try that and get back to you. Thank you for your help so far.
    I forgot about pin 7
    pin 7 to pin 7
    sorry
    Jul 2005
    1650
    jim how about a 9 to 25 pin? i could use the pinout for that cable config,... it's for a bridgeport with a dx II cntroller
    Mar 2013
    12
    Re: Mori Seki - Fanuc 11T
    Enter setting screen, choose 0,1,2,3,4 in I/O item. Try to?
  1. Mori Seki SL-1
    By MERCEDES in forum Mori Seiki lathes
    Last Post: 01-02-2015, 03:57 AM
  2. Mori Seki
    By br1 in forum Mori Seiki Mills
    Last Post: 09-06-2012, 05:39 PM
  3. Mori Seki SL-O H/Fanuc how to upload pro?
    By beckylee in forum Fanuc
    Last Post: 11-15-2009, 12:58 AM
  4. Replies: 3
    Last Post: 03-19-2007, 04:27 PM
  5. Mori Seki SL4
    By programmer1956 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 11:22 PM
