587,999 active members*
2,121 visitors online*
    May 2009
    41
    motor making noise
    Hello,
    Does anyone have any idea why my Y axis motor would whine? I set it up just like the X axis motor and that motor is fine?
    May 2006
    161
    Can you give some more information about your setup? Is this a stepper or a servo motor? Are both motors and drivers exactly the same?
    A PWM stepper motor can whine when the current limit takes place. Of course this should not happen in a proper designed drive.
    Todor
  1. Stepper motor noise?
    By Drools in forum CNC Machine Related Electronics
    Last Post: 02-16-2013, 01:34 PM
  2. Motor Humming Noise?
    By Dman in forum Hobbycnc (Products)
    Last Post: 11-10-2008, 01:03 AM
  3. Lead screw making noise
    By clembrant in forum Linear and Rotary Motion
    Last Post: 01-27-2007, 04:48 PM
  4. Motor noise
    By mjarus in forum Mini Lathe
    Last Post: 04-04-2006, 03:57 AM
  5. noise from motor
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 05-14-2003, 01:43 AM
