![Quote](images/misc/quote_icon.png)
Originally Posted by
rich_cree
Hi everyone. I'm struggling a bit to get my motors running right. I'm running Mach 3, with a Gecko 540 and Kelling 48V power supply & motors on a Taig mill.
I managed to calibrate everything fine, so each axis moves what it says it should when I ask it too. I tried some of the wizards in Mach 3 and they all seemed to work ok.
My problems come when I tried to cut my first proper part. I generated the g code in meshcam and I was really conservative with the feed rates (didn't want to do any damage). It seems my motors just don't run at all if the feedrate is too low. By low I am talking about 4ipm (100mm/min). Surely I should be able to run the motors this slow?
The part I test cut looks a mess. It's all of about the right dimensions but the circular pockets are all out of round, and the external walls are a bit chewed up where I'm guessing the mill has lost/gained steps.
Any ideas why my motors stall at low speeds? Is this normal???
Thanks for any help guys!
Rich
