603,953 active members*
2,862 visitors online*
Results 1 to 12 of 12
    Apr 2004
    34
    My CNC Router Plans
    I have just started designing my first CNC Router.
    I would appreciate any critques or suggestions on the structural design in the model below.
    I'm using Thomson supported rails with SPB-8-OPN and TWN-8-OPN pilowblocks/bearings.
    Z axis 4" travel
    Y axis 14"
    X axis 30"
    I'm using off the shelf aluminum (www.onlinemetals.com) channel (8"x2"x0.375"), angle (3"x3"x0.375") and plate (1/4")
    The table is not yet supported in model below.
    I'm hoping to route wood (hard and soft) and aluminum...
    Apr 2004
    34
    The model of the cnc router
    hmmm, here goes again (attaching the model picture)
    Mar 2004
    1147
    sweet rendering- sw2004?
    too dark though! please post more!
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    Apr 2004
    34
    I'm using Rhino3D (www.rhino3d.com) v2.0. Thinking about upgrading to 3.0 if a good CAM package is available as a plugin for a reasonable price.
    I'll post more tomorrow...........maybe my monitor is set for too bright, I'll try to brighten it up.
    Apr 2004
    34
    My CNC Router Plans (more pics)
    more pics.........
    Apr 2004
    34
    Jan 2004
    379
    looks good so far.. I'd like to see pics of a completed design including motors.
    Unless the table is really meant to float.
    Apr 2004
    34
    No, not meant to float......
    I'm creating the model as I find parts (on ebay or whatnot).
    Right now, I'm trying to find what I'll be using for leadscrews. I have one bid on ebay for the Y axis, but.....haven't won it yet. I've had trouble getting the acme rod or ballscrews for a reasonable price at the size I need. I have lot's of woodworking equipment, but no metalworking equipment for turning down the ends of acme rods for bearing mounts, etc....
    I just got my used thomson rails and pillowblocks in yesterday, their in pretty good shape, the 36" rods aren't tapped for mounting to the supports (guess you have to make sure you ask every possible question before buying used equip.) even though I bought both from the same guy over the phone after doing a "Buy Now" on the 18" set for the Y axis. Now I've got to find a machine shop that can tap those case 60 rails.
    more to come ............
    May 2003
    267
    In my opinion, the bearings and rods will allow some un-needed movement. I had this experience after using 1/2" dia. Thompson pillow block bearings on my Z axis. However, the length of the rods on my Z axis is about 27" so it might not matter for smaller machines. I am planning to buy THK bearings since I feel they do not have a lot of play or un-needed movement.
    My bearings has a feature that compensates for misalignment. However, this feature allows for x,y,z axis to wiggle some instead of being sturdy.
    This is just my own opinion.
    Thanks,
    Mar 2003
    35494
    George, after looking at your machine (thread here http://www.cnczone.com/forums/showth...&threadid=2865 ), I would guess your "un-needed movement" is from that big router hanging 2 ft below the gantry. You have a big lever, which doesn't take much force to twist the gantry beam.
    Clyde's, on the other hand, does'nt extend beyond the y-axis shafts, so it would take much more force to get it to flex. A more compact, and sturdier design imho.
    George's machine is a good example of the trade-offs involved when trying to make bigger routers.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2004
    34
    George, Thats a nice monster machine
    When I first started the Y Axis/Z Axis model, I realized that I would have to give up some Z Axis travel to prevent the lever action from being too great. I still hope that a 4" travel will not be too much (may reduce to 3-1/2").
    I was going to make the Z Axis 4-7/8" (8-3/8" rail minus the 3-1/2" long TWN8OPN pillowblock) But I didn't like the looks of the lever this created against the Y Axis rails. I think my intuition likes the distance between the Y axis rails to be 2 x the length of the lever created by the Z axis at it's lowest point.
    Apr 2004
    34
    After looking at the view of the rendering above, I see that I can spread the Y axis rails out so that the center of the rods (ends of rods in picture) align with the ends of the Z axis rods and get more support.
  1. Need a complete 3-Axis CNC Router plans
    By ezland00 in forum DIY CNC Router Table Machines
    Last Post: 04-01-2010, 05:06 AM
  2. Help to choose CNC Router Plans.
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 01-20-2010, 08:50 AM
  3. Cad Cut Cnc Router Plans On A Budget ????
    By jsatter in forum DIY CNC Router Table Machines
    Last Post: 11-27-2003, 01:17 PM
  4. Cnc Router table Plans and ideas
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 11-13-2003, 03:12 PM
  5. DATA-CUT CNC Router Plans
    By CADCAM GUY in forum DIY CNC Router Table Machines
    Last Post: 09-30-2003, 04:41 PM
