587,262 active members*
3,407 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > My G0704 Setup, almost done.
Results 1 to 11 of 11
    Feb 2012
    24
    Heres a quick vid of my G0704 making some chips after getting my chip tray and flood coolant setup done. Just need to get the rest of the full enclosure built and the machine will be fully done and ready to start making some money for me.
    G0704 new chip tray and flood coolant - YouTube
    Heres some pics of the first thing I made for someone once the machine was done being CNCd.
    Oct 2006
    210
    Those parts are pretty. Steel?
    Feb 2012
    24
    Yep, tool steel.
    Man, those came out great. If you don't mind could you tell us what speeds/feeds/tools you used to make those?
    Feb 2012
    24
    I used a 1/4 HSS Endmill for the pockets, 10ipm, 800rpm, 0.040 doc per step down.
    Tops and bottoms were face milled with a 2" sandvik 390 4 flute cutter, 1500rpm, 15ipm.
    Sides were roughed with a 3/8 carbide rougher, and finished with a 3/8 carbide altin coated end mill at 1300rpm, 0.005woc at 10ipm. If I remember correctly.
    Thanks for the info. I usually don't do any steel parts, but I have a project coming up and would have to start from scratch with my feeds and speeds. I assume that the end mills were all 4F. Correct?
    Feb 2012
    24
    Yeah, all my end mills are 4flute. I have done pretty much all steel parts since I got this machine up and running. Have only really cut some aluminum just to satisfy my curiosity. All I machine at work is steel, it's the only material I really know. I would be lost if I switched to aluminum. Lol
    Jan 2011
    141
    Nice work! Looks great. Any details on the CNC conversion? Steppers used etc..?
    Feb 2013
    164
    Is that a 6" Glacern vise? How is it with the G0704? It looks huge.
    Feb 2012
    24
    Quote Originally Posted by zer0fighter View Post
    Pretty much just a standard G0704 cnc conversion. 570oz motors on the X&Y, and a 906oz motor on the Z. C7 ballscrews, and motor mounts from Billy.
    Quote Originally Posted by zamazz View Post
    No, its a 5" vise. It is kinda big, looking back on it I wish I had gotten the 5" CNC vise from Tormach, it has less stick out on the back and can be laid flat on its side. But the Glacern is really nice quality, so im not to upset about it.
    Feb 2010
    3447
    Milling man!
    Looking good! I see your in Seattle, I'm down in Eatonville. Nice to have other members in the area!
  1. No Joy with my New G0704
    By DogWood in forum Benchtop Machines
    Last Post: 07-05-2016, 05:49 PM
  2. G0704 Issues, First Setup
    By DRock in forum Benchtop Machines
    Last Post: 09-06-2015, 06:27 PM
  3. G0704... Yes Another One ;)
    By ww_kayak in forum Benchtop Machines
    Last Post: 05-27-2013, 03:47 PM
  4. G0704 setup as a lathe...
    By lcvette in forum Benchtop Machines
    Last Post: 02-11-2012, 03:27 AM
  5. Replies: 13
    Last Post: 06-30-2011, 03:34 PM
