603,957 active members*
3,504 visitors online*
Page 2 of 5 1234
Results 21 to 40 of 87
  1. #21
    Feb 2004
    813
    I went back to work tonight; and finally got to make the X axis parts; a few nights drill and tapping plus a few small details and it will be complete for manual work; I'll post a pic once its assembled
    Next will be the CNC re-fit for the cross slide; the X is already done and the belt/pulleys are coming
  2. #22
    Feb 2004
    813
    As promised; the drive for the X axis; the bronze spacer is a dumby just till the timing belt pulley arrives
    The overall shot of the lathe; I'll engine turn finish the whole thing once I'm happy with the workings
    Next will be adding steppers; the alum support for the X axis stepper is long untill I establish the right belt length; I've ordered a 6.5" center to center with the 15 tooth pulleys for now
  3. #23
    Feb 2004
    62
    Impressive... I can't find more words.
    /U
  4. #24
    Oct 2003
    399
    It's amazing to see what a skilled person can do with a few pieces of metal. I'm trying to scoop everything up and learn as much as I can . Really cool, thanks for sharing it with us, Stevie!
    Arvid
  5. #25
    Mar 2004
    1306
    Nice work Stevie.
    To your question about motor size, a friend of mine CNC'd a Emco Unimat which is about the same size with NEMA 17's.
    http://www.pcspeed.keyspace.de/unima...unimat_cnc.htm
    It worked fine. Not exactly fast rapids, but usable. Are the NEMA 17's you have low inductance?
    You are probably better off with a Nema 23 on Z.
    Regards,
    Mark
  6. #26
    Feb 2004
    813
    Thanks for the link; it's just a bit smaller than mine
    I've decided on 23 sized
  7. #27
    Nov 2003
    299
    Amazing work. Keep us updated...
  8. #28
    Feb 2004
    813
    I'm thinking the compound can be removed for the CNC use; I can always replace it for manual work
    I'll increase the cross slide capacity that way too; I feel 5/8" max turnable dia is a bit limiting so the prospect of mounting a 4 or 3 jaw is always within the range of possiblities
  9. #29
    Feb 2004
    813
    latest update
    Here is the X drive with the handwheel support off; inside you can see the 2 small ball brgs that support the leadscrew; there are 2 more just behind the timing pulley
    I decided since the lathe will now be CNC controled I'd need it to be as free as possible; hence the next 3 pics; the first is the handwheel support for the cross slide; here I have machined the big dia to take a ball brg; the support holding screws had to be re-drilled deeper to make room
    Here is the back of the hand wheel; I machined just a few thou off to make the brg fit (I got lucky on this one)
    And now the oppisite end of the cross slide lead screw; I machined the brg dia into the cross slide block and re-machined the leadscrew down to suit; just behind the brg is a wave washer to keep tension on the set-up (got it from a 17 sized stepper)
    I still have to make the drive coupling that will take the place of the small lock coller
  10. #30
    Feb 2004
    813
    I got home and found the first of the Compumotor microstep drivers/motor combo
    I used the self test to run the motor at 1-r/p/sec; just to test the drive/motor and to see how the motor which is nema 23 sized would perform; it ran the saddle up and down the bed with no problems; I even asked my little girl to try to stop the saddle; she could not and other than the motor humming a bit; she had no effect at all.
    The drive is a Zeta4 with the matching motor I think it's about 65oz/in holding; bigger motors can be used with this drive all the way up to a 400oz/in monster; I have the Japan servo 310oz/in but these are for my mill project
    I've never felt the power of a stepper before; and although I did manage to make it skip steps under the self test function; I'm impressed; for a small one; it's got some push
    So with the other drive and motor arriving tomorrow; next will be the mountings for the steppers (and one coupling) I'm hoping to be moving it with computer control soon
  11. #31
    Apr 2003
    1873
    We are anxious for you as well Stevie.
    I have a Haas CNC mill here at the shop but all the fun you guys are having is making me want to get something CNC going on at home. I have been over the months putting together some parts, and I think a router/mill may just be the ticket.
    EDIT:
    It has to be something that is noisy enough to make my wife mad
    Ken
  12. #32
    Feb 2004
    813
    There's nothing like something to make them mad; mine's always mad at me; just so long as i still get my nummies I'm ok with the mad thng
    ooops edit; that should have been nummies
  13. #33
    Feb 2004
    813
    Hey Ken
    Great news on the Mill front; I just won 2 35mm THK slides 1 meter long with 4 trucks on eBay; I got the last bid with 2 seconds left; $202.50; I'm pleased; my wifes pi**ed; so I guess it was a good night all round
  14. #34
    Apr 2003
    1873
    Great Stevie,
    Really good price, I got a set of HSR25 by 32" with 4 blocks and paid 252.00 and thought that was a good buy, but not as good as you got. And you got the added bonus of getting your wife P***ed Man some people get all the breaks, mine just looked at me like I was crazy. I am not Crazy, I don't care what everyone else says, I am not crazy, I am much better since I had my treatment
    It will be a while before any mummies for Stevie
    Keep us posted on that sweet little sucker
    Ken
  15. #35
    Feb 2004
    813
    And what are the rails for; is the cat out of the bag
    come on; spill the beans; your about to build a home mill arn't you
    That will be the end of your nummies too
  16. #36
    Apr 2003
    1873
    Yeah, I admit it, I have been putting together over some months items to build a CNC router/mill to play around with at home. Not really all that set as to size but not too large maybe a cutting area of 36" x 30" x 6" . You can't be a CNC fan and not want to build something can you?
    I have a very powerful 3hp x 10,000 rpm motor I would like to drive it remotely with but have not really spent a lot of time figuring how or where to place it, it is bigger then a router, may just go with a router to simplify things.
    May start on the plans soon and begin building it come fall when business slows down.
    Ken
  17. #37
    Feb 2004
    813
    It lives
    Yes I know the z axis is just cobbled together (motor mount) but the mill at work is tied up this weekend; it will be similar to the X axis motor mount
    It will now move under turbocnc control; I am 1 happy camper
  18. #38
    Apr 2003
    1873
    And you have a right to add "Proud" to that statement as well Stevie, it is one sweet setup.
    Ken
  19. #39
    Feb 2004
    813
    Got the cross-slide stepper mount made today on my lunch time; it's a 2 piece mount with a base and the outer plate for the motor; it's screwed to the inner piece with 4-40 countersunk screws; then the inner is screwed to the saddle with 6-32 in counterbored holes
  20. #40
    Sep 2003
    1490
    It’s a beautiful piece of equipment, you can be very proud. Enough said.
    It would be so nice to see a video of it running.
    Hager
Page 2 of 5 1234
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Manual lathe CNC conversion
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2005, 09:56 PM
  3. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
  4. The start of a big CNC project...
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2004, 11:34 PM
  5. Taig lathe Threading and CNC questions
    By anoel in forum Mini Lathe
    Last Post: 01-12-2004, 10:43 PM
