587,584 active members*
3,681 visitors online*
Page 1 of 15 12311
Results 1 to 20 of 283
Hybrid View
    Jan 2005
    1050
    My steel frame small router (Madvac Inspiration)
    HI All,
    check out the pictures and comment. I am working 8 + 4 hours with 3 hrs travel add on daily to office. I might type much less and post more pictures.
    might be - end up with more typing than pics- you never know
    Also inspired by Hayden's router and the Madvac.
    Enjoy
    Jan 2006
    297
    Your new router
    contactirfu,
    Your new router project looks great ! Where are you finding the time & resources to work on these routers. I'm very impressed. I e-mailed Hugo and he's testing rev. 00E. cross your fingers and say the right words to the right Gods, I am
    Tenmetalman
    Jan 2005
    1050
    Quote Originally Posted by tenmetalman View Post
    contactirfu,
    Tenmetalman
    Actually I totally drained of energy paul, think i will be on drugs sooner and grow older than others
    well the time i mentioned in my previous post and the resources, i took up a bank loan for this!
    hope all turns up well .........only hoping for the best yet!
    Praying yes,
    Sep 2007
    17
    Great built, you are very "devotee", may I know your energy source ?
    Sep 2007
    9
    its looking great. i like how you're using supported rails rather then just the end supports. thats going to make it really precise on the cuts. good job. keep it up.
    http://www.putfile.com/powernaudio "some of my car audio install page ",
    maybe a CNC router will make my audio enclosure builds allot easier. lol
    Jan 2005
    1050
    Quote Originally Posted by PowerNaudio View Post
    It will also help me keep the mounting easier and i dont have to probably get the rail mounting either epoxied or machined, though I know it might have helped, i just dont have that sort of metal powder epoxies here.
    Just finished mounting the x rail yesterday and got to move it easily. will post a video soon of the rail functioning.
    RGDS
    Irfan
    Jul 2007
    31
    Hello,
    Looks good so far. Have you checked the straitness of the steel you are mounting the supported rail to, comparing the left and right x-axis spans? Also, have you added some weight to the center to of the X-axis span to simulate the gantry weight, checking for deflection. The way it is designed, you could still add a vertical beam under the center point if that is a problem. Looks good though!!
    If you need, I could stress that frame for you to see any possible deflection on the cutting bet or linear rails etc. But I don't think it will be a problem, just know our services are here if you need them.
    Keep up the good work!
    Regards,
    Brian
    WWW.CNCRouterSource.com
    Jan 2005
    1050
    Brain,
    Thnks for ur response, the square tubes I cut were straight and since after mounting the rails yesterday has given me more confidence inteh bolted type of fitting and I suddenly realised that I am a better metal worker too apart from being just a regular mechanical engineer.
    I have levelled teh table to the best of my eye and mounted teh rails and they do work good and flat.
    Thanks for offering to stress the frame out for me, but I am in India, so its outta Q!
    BTW my DAD and my cousin were a great help in the build. The only pain part in assembling a bolted design is the number of times you have to dis-assemble and re-assemble, its just PIA!
    Thanks for all comments
    RGDS
    Irfan
    Jul 2007
    31
    contactirfu,
    No problem. I did mean stress it through software in a digital format of course lol. I too am a mechanical/aerospace engineer.
    Keep us posted on your progress!!
    Regards
    Brian
    Jan 2005
    1050
    Quote Originally Posted by gth629e View Post
    contactirfu,
    Regards
    We can do that here too!, and I myself dont trust it much. sure will keep all posted! my internet connection at home is all f'd up, need to get it running to post the latest videos and pics.
    Jan 2005
    1050
    Update onX-axis
    Chk out the pictures - they speak for themselves, Manjeet thanks for the end blocks man. U rock.
    The men in the picture are my DAD and Cousin! they are my helpers on weekends and DAD is a full time help too. DAD organizes most of the stuff while I am away at office. Man DAD's Rock too.
    RGDS
    Irfan
    Jan 2005
    1050
    Gantry update
    Finished the gantry almost!
    The20mm dia linear slides took quite a while to mount accurately,well it was done finally!
    Now need to build the Z axis tomorrow. Hope it comes out well.
    Also the y ball screw will be back from repair and end machining soon. I do have a lot to concentrate upon!
    Wish me luck guys!
    RGDS
    Irfan
    Jan 2005
    1050
    Z axis almost done!
    Hi All,
    Just an update!
    Finally satisfied with my Z axis done with tubes . originally planned out of Alu plate but finally done using mild steel tubes.
    Do post comments!
    RGDS
    Irfan
    Aug 2004
    3215
    machine is looking real good and strong
    Mar 2004
    1661
    Looking good, I like steel routers (have one myself). But I wouldn't call that one small...
    Sep 2007
    17
    Very nice and solid built, will definately give nice cuts. You should/may have some plans on keeping x rails clean while in use.
  17. #17
    Jan 2005
    1050
    Hi All,
    Thanks for your feed back, here are some videos of the pictures.
    http://www.youtube.com/watch?v=-S5dVGmrlEM
    http://www.youtube.com/watch?v=vmPT85_cxec
    Yup i do have some plans to keep teh X rails clean, will tell it out only when i do it! bcos may be I have more than one ideas to utilize on the machine.
    Also think I should't have called it a small machine - however considering that I will be building a mechmate soon - this is considerably small to that. so no problem there.
    RGDS
    Irfan
  18. #18
    Jan 2005
    1050
    Y axis ballscrew update.
    Had the end supports of the ballscrew made and mounted onto the machine for a look,the guy who reconditioned the screw SCREWED it up on the support end.
    It was in no way the dia of the bearing and now i need help,i will post some more photos requesting for help.
    Meanwhile enjoy these pics.
  19. #19
    Dec 2004
    411
    Hi
    Nice machine.
    I have suggestion re. improving your cutting torque.
    I think a variable height table that can be raised lowered by whatever means achievable would help.
    If you cut everything at the height the table is now I think you will find some materials easier to cut than others.
    Basically the harder the material, the less you would want to extend your z axis.
    That leads me onto the second point..... Given that your X rails are low and your Y rails are high, I would beef up the gantry sides as much as possible.
    Clearly there are a few introduced moments in your design and those will be your points of potential flex.
    Hope that helps.
    Enjoy
    Andy
    Drat, imperfection has finally stopped working!!
  20. #20
    Jan 2009
    396
    Quote Originally Posted by contactirfu View Post
    Hi Irfan,
    I have a question, the way you mount your linear bearing open type is on its side does it posed any problem at all if you have a much heavier Z axis?
    I will building mine soon and I need to figure out how to mount those linear bearing open type correctly all I know is just to lay them flat instead of on their side.
Page 1 of 15 12311
  1. New home made MadVac CNC router
    By oneyaker in forum DIY CNC Router Table Machines
    Last Post: 02-05-2011, 12:37 PM
  2. My Steel Frame Router
    By epineh in forum CNC Wood Router Project Log
    Last Post: 07-06-2009, 03:27 AM
  3. My 2nd Steel Frame Router
    Last Post: 07-12-2007, 08:35 AM
  4. Hardened steel tubes, suitable for frame cnc router ?
    By vroemm in forum Mechanical Calculations/Engineering Design
    Last Post: 07-09-2007, 08:29 AM
  5. Need recomendations on 2" square steel tube for router frame.
    By danm in forum DIY CNC Router Table Machines
    Last Post: 11-15-2005, 01:21 AM
