603,967 active members*
1,918 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need a copy of the Probing Macro O9811
    Nov 2016
    21
    We somehow lost one of the Macro Programs on our Fanuc 0i Mill with a Renishaw OMP60 Probe and need only the one used for Single Point Measuring, O9811
    It's not very long, only about 30 or 40 lines as I recall.
    We only need the one, single Macro.
    Everything else with the probe is functioning fine, we just accidentally lost one of the Macros.
    Thanks!
    -S
    Aug 2006
    171
    Re: Need a copy of the Probing Macro O9811
    O9811(REN*XYZ*MEASURE)
    G65P9724
    IF[#19EQ#0]GOTO1
    IF[#20EQ#0]GOTO1
    #3000=91(ST*INPUT*MIXED)
    N1
    IF[#19EQ#0]GOTO2
    IF[#11EQ#0]GOTO2
    #3000=91(SH*INPUT*MIXED)
    N2
    IF[#20EQ#0]GOTO3
    IF[#13EQ#0]GOTO3
    #3000=91(TM*INPUT*MIXED)
    N3
    #1=135
    WHILE[#1LE149]DO1
    #[#1]=#0
    #1=#1+1
    END1
    #10=#5041(X*START)
    #12=#5042(Y*START)
    G31X[#10-#502]Y[#12-#503]F#119
    IF[ABS[#5061-[#10-#502]]GE#123]GOTO22
    IF[ABS[#5062-[#12-#503]]GE#123]GOTO22
    #30=-1(DIR*FLAG)
    IF[#24NE#0]GOTO5
    IF[#25NE#0]GOTO7
    (Z*MOVE)
    IF[#26EQ#0]GOTO225
    #7=5203
    IF[[#5043-#116]LT#26]GOTO4
    #30=1
    N4
    G65P9726Z#26Q#17
    IF[#149NE0]GOTO21
    #135=#10
    #136=#12
    #137=#126-#116(Z*POS)
    #138=#137
    IF[#8EQ#0]GOTO45
    #138=#138+#[2000+#8](SIZE)
    N45
    #142=#137-#26(Z*ERROR)
    #143=#138-#26(SIZE*ERROR)
    #145=ABS[#142](T*P*ERR)
    #146=#143*#30(METAL*CON)
    GOTO9
    N5(X*MOVE)
    IF[#25NE#0]GOTO225
    IF[#26NE#0]GOTO225
    #6=#500
    #7=5201
    IF[#5041LT#24]GOTO6
    #6=-#500
    #30=1
    N6
    G65P9726X#24Q#17S#500
    IF[#149NE0]GOTO21
    #135=#124+#6+#502(COR*SKIP*POS)
    #136=#12
    #138=#135
    IF[#8EQ#0]GOTO65
    #138=#138+#[2000+#8](ACT*SIZE)
    N65
    #140=#135-#24(X*ERROR)
    #143=#138-#24(SIZE*ERROR)
    #145=ABS[#140](T*P*ERROR)
    GOTO9
    N7(Y*MOVE)
    IF[#26NE#0]GOTO225
    #6=#501
    #7=5202
    IF[#5042LT#25]GOTO8
    #6=-#501
    #30=1
    N8
    G65P9726Y#25Q#17S#501
    IF[#149NE0]GOTO21
    #135=#10
    #136=#125+#6+#503(Y*SKIP*POS)
    #138=#136
    IF[#8EQ#0]GOTO85
    N85
    #141=#136-#25(ERROR)
    #143=#138-#25(SIZE*ERROR)
    #145=ABS[#141](TP*ERROR)
    N9
    #147=#30
    IF[#23EQ#0]GOTO10
    G65P9730H#11M#13S#19T#20W#23X#24Y#25Z#26
    N10
    IF[#21EQ#0]GOTO11(U*UPPER*TOL)
    IF[ABS[#143]GE#21]GOTO23
    IF[#145GE#21]GOTO23
    N11
    IF[#11EQ#0]GOTO13
    IF[ABS[#143]LT#11]GOTO12
    #148=1
    N12
    IF[#120AND4EQ4]GOTO13
    IF[ABS[#143]LT#11]GOTO13
    G0X#10Y#12
    #[3006-[[#120AND8]/8*6]]=1(OUT*OF*TOL)
    N13
    IF[#13EQ#0]GOTO15
    IF[ABS[#145]LT[#13/2]]GOTO14
    #148=2
    N14
    IF[#120AND4EQ4]GOTO15
    IF[ABS[#145]LT[#13/2]]GOTO15
    G0X#10Y#12
    #[3006-[[#120AND8]/8*6]]=1(OUT*OF*POSITION)
    N15
    IF[#20EQ#0]GOTO19
    IF[ABS[#146]LT#22]GOTO19(NULL*BAND)
    IF[#9NE#0]GOTO16
    #9=1
    N16
    G65P9732T#20C[#146*#9]Z#26
    N19
    IF[#19EQ#0]GOTO24
    G65P9732S#19Z#26W1.0
    GOTO24
    N21
    IF[#149NE2]GOTO22
    G0X#10Y#12
    #3000=93(PROBE*FAIL)
    N22
    G0X#10Y#12
    #3000=92(PROBE*OPEN)
    N225
    G0X#10Y#12
    #3000=91(XYZ*INPUT*MIXED)
    N23
    #148=3
    IF[#120AND4EQ4]GOTO24
    G0X#10Y#12
    #[3006-[[#120AND8]/8*6]]=1(UPPER*TOL*EXCEEDED)
    N24
    G0X#10Y#12
    M99
    Attached Files Attached Files
    "Teach the ignorant, care for the dumb, punish the stupid."
    Nov 2016
    21
    Quote Originally Posted by Species8472 View Post
    Thank you, that is what I needed!
    -S
  1. Replies: 0
    Last Post: 09-09-2024, 04:19 PM
  2. Macro Programming Question, Z Probing Macro Problem
    By hkinkade in forum Mach Wizards, Macros, & Addons
    Last Post: 11-27-2023, 07:11 PM
  3. Macro Programming Question, Z Probing Macro Problem
    Last Post: 11-27-2023, 07:07 PM
  4. Probing macro
    By Jurjen in forum Fanuc
    Last Post: 10-23-2020, 11:27 AM
  5. macro's for probing?
    By REVCAM_Bob in forum G-Code Programing
    Last Post: 06-10-2008, 02:17 AM
