603,945 active members*
3,575 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > need help with new build and Airsoft Mach 4 board
Results 1 to 6 of 6
    Nov 2018
    7
    this build has a liitle bit of everything going on with it but would need some input, this is the third machine build I have done the first 2 were the very basic build this and plug theis wire in that sopt and it should all run, But this one is a little more in depth especially the Card!
    I am build a machine that is combining parts from Makerstore and yuyong industries, and want to run this with MACH 4, i ALREAD HAVE THE SOFTWARE ALONG WITH CONTROL CARD FROM AIRSOFT USB FOR MACH4, i HAVE NEVER WIRED ONE OF THOSE CARDS UP AND IT SEEMS SOMEWHAT challenging but it just may be me another gentalman on a FB site was cheering me on and trying to convice me that it is the same as the other comtrollers that I did on my 2 entry level machines.
    Is there a clear concise schematic that would take me through it step by step? I will also be running closed loop steppers and have the airsoft Mach 4 control card?
    Nov 2013
    5412
    Re: need help with new build and Airsoft Mach 4 board
    I have used Mach4 for eight years and am pretty familiar with all the manufacturers of different Mach4 ready motion controllers but I've never heard of one called 'Airsoft'.
    Please post a picture of it, and who makes it?
    Craig
    Oct 2009
    483
    Maybe he meant Artsoft?
    Nov 2013
    5412
    well yes I considered that but Artsoft do not produce a motion control board at all, they provide Mach4 software only. Yet OP definitely refers to a piece of hardware.
    Craig
    Apr 2018
    159
    Perhaps --perhaps-- there is a word left out, and what he really meant was: "airsoft approved Mach 4 control card".
    Where did I get that idea? See post #1 in this thread: https://www.machsupport.com/forum/in...0610#msg270610
    Nov 2013
    5412
    I suspect you are right, he has an RnR motion board, which are big trouble. They work with Mach3 , mostly or sometimes, but they do not work with Mach4 at all.
    Craig
  1. Mach 3 breakout board
    By MAHNKEN in forum CNC Machine Related Electronics
    Last Post: 02-04-2021, 10:33 AM
  2. G0704 stock spindle control board to mach 3 via C32 board.
    By ballistic42 in forum Benchtop Machines
    Last Post: 09-22-2016, 02:47 AM
  3. RFQ: Milled Aluminum bolt carriers (airsoft)
    By awlogue in forum RFQ (Request for Quote)
    Last Post: 06-09-2015, 04:36 PM
  4. Mach 3 with a PMDX 126 Board , 107 spindle board
    By jandalaser in forum Mach Software (ArtSoft software)
    Last Post: 05-18-2012, 09:38 PM
