Hi!
I am new in the CNC world and run into my first problem. I got everything installed and started at slow speed and everything worked fine, but when i began to increase the speed and acceleration for my axes in mach3 my steppers began to make terrible noises and eventually stalled. I looked for a solution to my problem and found a way to reduce noise by introducing an inertial damper. It seemed to be a really easy solution until I began to realize that my steppers are only single shaft and that it would not be easy to mount an inertial damper on my stepper.
So my question now is if anyone of you has had the same problem or has a solution to my problem
Cheers
Chris
PS:
CNC mill is a simple 3040 from China
Stepper drivers are TB6600
Stepper motors are 57HS76 3A 270 oz/in
