603,897 active members*
5,777 visitors online*
Results 1 to 5 of 5
    May 2016
    32
    Need Help--Saturn I rack spacers
    Hi Guys.
    I have a Saturn I 4x4 machine and am installing the black rack spacers
    that Nate kindly sent me. Nate sent me 6 spacer bars and a bag of longer
    machine screws to install them.
    Do you install two spacer bars per side or four spacer bars per side to extend
    the toothed rack outward?
    The reason I ask is the fact that I have six spacers. If it is two per side then
    I have two left over. If it is four per side, then I am two short.
    To me, it seems I should have either 4 or 8 spacers not six. Can you clarify this, please?
    Also when installing the spacers, they do not butt end-to-end but have a gap
    of about two inches between them. I assume this is correct?
    Thank you!
    Redcedar
    Re: Need Help--Saturn I rack spacers
    Quote Originally Posted by Redcedar View Post
    Hi Guys.
    Thank you!
    Redcedar
    2 per 54 in rack. 3 racks makes 6 spacers. Don’t forget the rack on the X-Axis.
    The spacers will have a small gap between them. Drop them in from the top. The easiest way is to put the bolts in that hold the rack and leave a gap, then drop the spacer in from the top.
    Fine Line Automation
    www.finelineautomation.com
    May 2016
    32
    Thank you, Nate!
    I appreciate the quick response and the clarification.
    You are correct, I had forgotten about the rack on the X-Axis.
    Now I can back to work on my machine! Thank you again.
    All the best.
    David
    Nov 2014
    714
    Not that you need this, David, but I did a video on installing the spacers -
    https://www.youtube.com/watch?v=vx5lJU2Tup8
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    May 2016
    32
    Quote Originally Posted by difalkner View Post
    David
    Thank you, David.
    That's an excellent video.
    I got the two Y-Axis spacers installed yesterday
    and will do the X-Axis today.
    Please keep posting videos! They are very
    helpful to me as I am just starting out.
    All the best to you.
    David
  1. Saturn CNC upgrade - Y axis spacers
    By difalkner in forum FineLine Automation
    Last Post: 03-17-2018, 09:50 PM
  2. DIY Eccentric Spacers for less than 40c each
    By NotSqueaky in forum Avid CNC
    Last Post: 01-25-2014, 06:16 AM
  3. Aluminum spacers
    By drivenfab in forum North America RFQ's
    Last Post: 09-23-2013, 04:03 PM
  4. Cat 40 Tool Holder Rack - Haas, Rack, or Benchtop
    By mecheng10 in forum News Announcements
    Last Post: 09-17-2011, 02:52 PM
  5. Alum Spacers
    By IHscout in forum RFQ (Request for Quote)
    Last Post: 08-21-2011, 01:55 AM
