603,326 active members*
3,357 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Need help with squealing MicroLux 7x14
Results 1 to 4 of 4
    Mar 2025
    Hello everyone:
    This is my first post here and I need some help figuring out what is going on with my mini lathe.
    I have a MicroLux 7x14 (model 82710) that I have used almost daily since 2010, and a couple months ago it began making a squealing/screeching noise when I run the machine.
    I'm trying to determine why the machine is making this noise, in order that I might perform some preventative maintenance before an actual breakdown.
    The screeching seems to be coming from the headstock. Could the bearing be wearing out? It doesn't make the noise every time I use the lathe, but it does worry me. I made a video so other could hear the noise it is making, but it is too large to load into the forum.
    Suggestions please!
    Thanks in advance,
    Mark
    Apr 2004
    5948
    Re: Need help with squealing MicroLux 7x14
    Have you been oiling it regularly? Usually a squealing sound indicates that the bearings are in deep distress, and may need replacement. But sometimes a little lubrication can work wonders, or maybe put things off a while.
    Andrew Werby
    Website
    Mar 2025
    Quote Originally Posted by awerby View Post
    Unfortunately, no I have not oiled it regularly so my bad! So I may have to replace the bearings!
    May 2024
    6
    Quote Originally Posted by CzechOne View Post
    Unfortunately Drift Boss, no I have not oiled it regularly so my bad! So I may have to replace the bearings!
    So bro doesn't lubricate the shaft often huh? Making noise is a problem I often encounter too. You really have to pay attention!
  1. Squealing in X moves!!
    By brianbonedoc in forum Novakon
    Last Post: 06-10-2017, 12:33 AM
  2. Replies: 124
    Last Post: 08-03-2012, 08:30 AM
  3. Micro-Mark Microlux 7x14 Mini Lathe
    By Jaime128 in forum Mini Lathe
    Last Post: 06-02-2010, 04:22 AM
  4. Microlux 7x14 Mini Lathe Conversion
    By TacPyro in forum Mini Lathe
    Last Post: 02-13-2009, 09:44 PM
  5. Squealing like a stuck pig.
    By Smitty911 in forum Benchtop Machines
    Last Post: 01-26-2008, 06:21 PM
