603,340 active members*
3,562 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Squealing like a stuck pig.
Page 1 of 4 123
Results 1 to 20 of 77
    Mar 2007
    242
    ok here's the set up. X-2, MACH 3, Gecko 203V, KDN Tools CNC conversion (no backlash, ok I can't measure that low), 2 Flute .500" cutter, 6061 aluminum >.500" plate, Feed 20ipm, depth of cut .020", Aluminum cutting fluid liberaly applied in front of cutting path = SQUEALING
    I've sped up and slowed down the cutter speed, increased and decreased the feed rate, it still persist.
    Any Ideas???
    Also does anyone know of a good speed feed calculator?
    How do you figure "Chip Load" per tooth?
    Smitty
    Jul 2005
    12177
    What type of toolholder; generally setscrew type are more rigid than collet. How much tool is sticking out; keep it back to have the minimum length possible.
    Chip load per toothis the distance the feed advances during the rotation of one tooth. So if you want a chipload of .005" per tooth on a two flute cutter running at 3000 rpm you multiply .0005" per tooth b y two teeth which equals 0.01" per revolution so at 3000 rpm the feed has to be 30 ipm.
    Generally to reduce squealing, actually called chatter, you want to increase the chipload; slower rpm or faster feed. But first make sure your tool is held securely and not sticking out too far.
    Incidentally 0.02" depth of cut is a bit skimpy; ten times this should be possible provided you do not run out of hp.
    Aug 2007
    135
    Quote Originally Posted by Geof View Post
    I have to disagree - for the purposes of roughing and holding the tool still, an endmill holder is more rigid. But for the purpose of chatter, and endmill holder is a wind chime compared to a collet. There's lots of data out there on this.
    Jul 2005
    12177
    Quote Originally Posted by toastydeath View Post
    ...But for the purpose of chatter, and endmill holder is a wind chime compared to a collet. There's lots of data out there on this.
    Okay give me some links.
    There was a recent thread about setscrew type holders that discussed this and I think the concensus was that these are more rigid than the ER, taper collet, type holders. My experience is that collet holders are simply not up to taking the kind of speeds, feeds and chiploads that a setscrew holder can handle.
    Mar 2007
    242
    Thanks here what I'm using
    The correct Collet (LMS) to hold a 3/8 end mill. It is shoved all the way up so that only the cutting edges are sticking out.
    So I should be taking deeper cuts? I watch the videos of Hoss doing depth and feed rate test and based my set up on that. He was taking 0.075 at 5ipm and it stalled.
    Oh I forgot to mention that the 0.500" plate is held to a second sacrifical plate with some wax paper that I bought for holding parts like this.
    I will edit the code to speed the feed rate up some and see if that helps.
    Smitty
    Jul 2005
    12177
    Quote Originally Posted by Smitty911 View Post
    ....So I should be taking deeper cuts? I watch the videos of Hoss doing depth and feed rate test and based my set up on that. He was taking 0.075 at 5ipm and it stalled....Smitty
    If you have limited power sometimes it is difficult to get enough load to prevent chatter before you stall the machine. And, despite what toastydeath suggests, I think you should try a setscrew holder. If it doesnt't help I will crawl back under my bridge and keep quiet.
    Mar 2007
    242
    How'd you get a Bridge?
    I thought only trolls went under bridges, I don't think you qualify as a troll.
    I'll have to run down to the corner Tool Shop and get one to try. It's only money at this point, and that's what hobbies are for.
    Smitty
    Jul 2005
    12177
    When I get a reply that treats me like a troll I will respond as one.
    I am not always sweetness and light.
    The noise could also come from a dulled cutting edge on the end of the mill or possibly chip welding. I have got a few import endmills that were not all that sharp out of the pack. On 6061 they possibly could have made a squealing sound but they would have been hot also and the surface finish would have been terrible. They were used on large equipment so they were taking heavy cuts and were only used for roughing so it didnt really matter. As far as the Collet vs. Endmill holder debate there is alot of debating back and forth with everyones opinion, to my knowledge there has not been any actual proof in the pudding tests that show one way or the other. This I do know. I have had endmills slightly slide out in a collet during heavy cuts which ruined a few parts in the batch until it was caught. The collet was name brand used very little with the correct size mill and it was tight. The movement was only .0025" but that was enough on that job. For roughing I will always use a setscrew type holder other than that either has proven adequate to me. Alum., Stainless, Toolsteel, Titanium I have used both in each and it is about the same story. With your depth of cut and feed in 6061 I would use either, but if I had a problem I would definately try another holder to rule it out if nothing else comes to light. Just my 2 pennys though.
    Aug 2007
    135
    Physics doesn't obey a consensus vote, and just saying an unqualified "rigid" doesn't mean anything in the context of machine tools.
    Endmill holders have a higher static rigidity, collet holders have a higher dynamic rigidity. Higher static rigidity means less deflection and overall holding force in the endmill. It won't slip, and it will stay straight at low RPMs. Higher dynamic rigidity means less deflection at high speed, and higher vibration damping at all speeds.
    The ASPE has a video series, one of which is Dr. George Tlusty. He determined the equations that describe chatter in machine tools, and it's a very robust presentation on how chatter occurs and why. If you're interested in the subject, I recommend finding the two-part presentation and watching it.
    I don't have any webpages on this, nor would I trust any, as the quality of information regarding machine tool dynamics is generally piss poor. The places I've seen quality vibration and chatter analysis of toolholders is in journal articles, personal conversations with people who have a doctorate in the subject, and from people who do high speed machining and have done vibration analysis as part of the toolpath. I believe there was a semi-recent issue of Modern Machine Shop that briefly detailed the advantages of collet holders, but I don't subscribe to it and don't know which issue it was.
    Nov 2005
    655
    Howdy Geof,
    Typo above, .0005 should be .005 (oops)
    feedrate = rpm x number of teeth x clipload per tooth
    rpm = (cutting speed x 3.8) / diameter of tool for mill or workpiece for lathe
    Cheers, Jack
    Walking is highly over-rated
    Jul 2005
    12177
    Physics doesn't obey a consensus vote, and just saying an unqualified "rigid" doesn't mean anything in the context of machine tools.........etc, etc,
    Well I guess I have been put in my place. Okay I will retire to my bridge.
    Jun 2007
    3738
    Wink LKots of teeth.
    I like people with lotsa teeth.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Mar 2007
    242
    I'll try that when I get to work.
    Thanks for the replys. I'll play with it when I get to work and see how it goes.
    I attempted to use the one in MACH 3.
    So any "noise" comming from the cutter is "chatter"? I thought it would be more of a stacato sound for some reason. The finish looked good.
    How does depth of cut impact the above calculations? So the Feed Rate and Spindle speed effect chatter, but depth of cut only has to do with hoursepower? I would assume that all three come into play.
    Neilw20,
    Lotsa teeth, THAT'S WHAT I'M TRYING TO MAKE. Less expensive than a trip to the Dentist, and you can polish 6061 to nice shine. Making my own bling.
    Smitty
    Jun 2004
    6618
    Neilw20,
    Smitty
    The hard part is welding them in place. Lots of chatter there.
    Lee
    Jun 2007
    3738
    Talking Great Idea!.
    Neilw20,
    Smitty
    I'm going to digitize my false teeth and make some brass ones. (heh,Heh)
  17. #17
    Jul 2005
    12177
    ....So any "noise" comming from the cutter is "chatter"? I thought it would be more of a stacato sound for some reason. The finish looked good.....
    You do mention a stuck pig squealing, that is going to be a high frequency; the tool is vibrating like a tuning fork at a high frequency. But the amplitude of the vibration is going to be very small, so small that its effect on the surface finish is probably not noticeable.
    If you calculated the rate at which the tips of the tool are hitting the work piece that frequency is probably in the region you would characterize as staccato; it is this staccato frequency which is exciting a higher harmonic frequency of vibration in the tool.
    This is why you play with speed, feed, depth of cut and cutter rigidity. Speed changes the excitation frequency, feed and depth of cut change the amount of deflection which can affect which harmonic is excited, cutter rigidity changes the resonant frequency of the cutter.
    Chatter is very complex and it is possible to analyse it mathematically and focus on certain components which can be dealt with separately. If you have a multi-million dollar machine ripping into huge blocks of aluminum for airplane wing spars you spend great amounts of money to maximize chatter-free metal removal so you go into these details. When you are just a little guy like me you work with experience. And when you are feeling generous you pass on advise based on that experience.
    Here are a couple more maybe relevant threads:
    http://www.cnczone.com/forums/showthread.php?t=49762
    http://www.cnczone.com/forums/showth...257#post394257
  18. #18
    Apr 2005
    863
    I agree you probably need to increase the chip load. Unfortunately the X2 is probably not rigid or powerful enough to support a higher chip load on a cutter that size. I don't use endmills over 10mm on my X2 because of this, in my opinion 1/2" is slightly too big for the machine.
  19. #19
    Mar 2007
    242
    OHT On Hobby Training
    Well, the wealth if not the correctness of opionions is always fun.
    I noticed that it would be more noticable while the Cutter was moving Left and reduced or completly eliminated moving right. It seemed to happen regardless of Full cutter or just the 75% stepover.
    I didn't notice this in my smaller cutters so that could be part of it as well.
    I saw the V-8 Block video on YouTube.com Do they cost to much to be called a hobby machine?
    So what I gather is I need to get some Aluminum, and test various speeds and Feeds, with different size cutters to find out what the machine can do. Log it all for future, and use those as starter points.
    These are HSS Two Flute, Uncoated, from LMS, all of the ones I have are like 3/8 shafts, should I get larger shanks?
    OK you know what I have for Cutters, What Should I be Purchasing and from where? I like Made in USA products if that helps.
    Smitty
  20. #20
    Mar 2007
    242
    Brass
    Quote Originally Posted by neilw20 View Post
    I heard Brass was Gummy to machine. Pun intended.
    Smitty
Page 1 of 4 123
  1. Stuck In Mm On Fanuc 18t, Help!
    By TEVAN in forum Fanuc
    Last Post: 01-14-2014, 01:36 AM
  2. SX3 -- my chuck is stuck, what to do?
    By krazatchu in forum Syil Products
    Last Post: 11-25-2007, 02:57 AM
  3. Help! am Stuck!
    By ImanCarrot in forum Uncategorised CAM Discussion
    Last Post: 11-16-2007, 09:34 AM
  4. dynapath stuck
    By kurth in forum DNC Problems and Solutions
    Last Post: 01-24-2006, 03:35 PM
  5. New to PICs, stuck, and need help
    By neildm in forum PIC Programing / Design
    Last Post: 08-04-2005, 11:58 AM
