603,844 active members*
4,434 visitors online*
Results 1 to 7 of 7
    Mar 2009
    106
    Need suggestions for EMC2 computer
    I've successfully installed EMC and have it running despite a severe latency problem (~900000). Surprisingly it does not seem to affect the results I get out of my gantry router but I would rather have things as they should be. I have installed EMC on 3 different computers and get similar results so now I am thinking of building a dedicated computer for the software. Can anyone suggest a motherboard and peripheral combination that will work reliably and hopefully be a low cost solution?
    Jul 2003
    1766
    I have used the intel atom boards with success.. Not stellar - but consistant.
    With the livecd install - latencys are under 20us.
    depends on what you need... only has 1 pci port.
    http://www.newegg.com/Product/Produc...-383-_-Product
    sam
    Jul 2003
    1766
    otherwise.. (used is good also)
    http://wiki.linuxcnc.org/cgi-bin/emc...l?Latency-Test
    sam
    Apr 2005
    462
    any computer will do
    Mar 2006
    474
    At first, I had a lot of trouble with latency spikes. After a lot of frustration and constant rebooting, while trying many combinations of BIOS setting, Video card, Network card, and even CD drive, I noticed that simply waiting 2 or 3 minutes after powerup takes care of the problem.
    I've been using EMC trouble-free for a year now.
    Apr 2009
    42
    Quote Originally Posted by vlmarshall View Post
    At first, I had a lot of trouble with latency spikes.[...]
    I have had very good experience using VIA EPIA-family boards for EMC2.
    The VIA's are not as "advanced" as Intel and AMD cpus, which mean that their BIOS mucks about a lot less in system management mode, than the "smarter" competitors.
    For real-time stuff like EMC2, that is a clear win for Via.
    Poul-Henning
    (..who writes Operating Systems for a living)
    May 2006
    122
    I had severe chronic latency when using the S3Virge driver, so I switched to the generic vesa driver and it's much better.
    I then found that I had latency spikes due to max cpu utilization, so I run htop to monitor what processes are overtaxing my cpu. Specifically I found that on my machine the renderer on Axis consumes a great deal of computation capacity... so I use the DRO - much better results.
  1. What improvements/suggestions for EMC2, if it was up to you?
    By chester88 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-15-2009, 10:00 PM
  2. 3D DXF EMC2 or 2D only?
    By klaymonster in forum LinuxCNC (formerly EMC2)
    Last Post: 01-14-2009, 11:22 PM
  3. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  4. EMC2 to diy CNC
    By dakiller322 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-05-2007, 06:16 AM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
