603,336 active members*
3,934 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > Need a Technique to Set the Z Axis to Zero
    Jan 2007
    117
    I have several routers running and decided to try a lathe. It's almost done. Need help with a technique to calibrate the tool tip to the center of the spindle. I'm using Mach 3 Lathe.
    This is probably a simple/stupid question, but I'm out here operating in a bubble.
    Thanks in advance.
    Jul 2005
    12177
    The most straightforward approach is to take an OD cut and a face cut on a piece of stock. Enter the Z coordinate for the face cut into the Z tool offset table. Enter the X coordinate for the face cut into the X tool offset table and then add half the measured diameter of the OD onto this. That puts X on the spindle centerline.
    NOTE: In saying add half the diameter I am assuming your machine is going to display machines coordinates as radial values for the X axis; if the machine displays the X position in terms of diameter then it is the full measured diameter that is used.
    Jan 2007
    117
    Geof,
    WOW, That was quick. Thanks for the help.
  1. tool making technique
    By sharathchandar in forum MetalWork Discussion
    Last Post: 10-25-2007, 02:05 AM
  2. roughing/finishing technique
    By fpworks in forum Hard / High Speed Machining
    Last Post: 10-14-2007, 05:33 PM
  3. Ball-Bar measuring technique and mapping ballscrew
    By AKFALAR in forum Linear and Rotary Motion
    Last Post: 05-07-2007, 02:20 AM
  4. What's your technique for routing out parts
    By originator in forum MetalWork Discussion
    Last Post: 02-04-2007, 08:33 AM
  5. Control Technique Digitax DBE 750 AC Servo-Drive
    By GalaticDan in forum Servo Motors / Drives
    Last Post: 09-16-2005, 12:32 PM
