I have been looking into the water jet market and I found out real quick
that I don't have the funds for one.
So I'm going to build my own 5x10 table go plasma using Mach as the controller software.
My plan is to use the plasma to build a customer base and either build
a new table and put a water jet pump on it or put the pump sytem
on the existing table.
Could you guys refer me to some nesting software that will generate
cut paths?
From what I understand the software the water jet software slows cut speeds when cutting around corners to keep the cerf to a minimum so the soft ware will need to work with plasma or water jet.
