587,143 active members*
4,076 visitors online*
Page 8 of 13 678910
Results 141 to 160 of 247
  1. #141
    Mar 2003
    6855
    Quote Originally Posted by miljnor
    Thats very cool, Thanks!
    1. does the fact the the gantry moves to and fro make the focusing any harder?
    2. how far can the laser be from the focusing beem to cut?
    3. can you engrave with this kind of laser
    4. if so, how far can you be from the focuser to engrave.
    5. sorry to be a pest!
    1- Yes it makes it very hard to adjust but their really is no choice for the given set-up.
    2- I can cut 1/2" no problem any thicker the beam won't go all the way through. My FL is 2.5 inch.
    3- Yes you can engrave no problem, I have not tried that yet.
    4- as far as I know you just modulate the frequency of the beam not the FL of it.
    5- No problem
  2. #142
    Jun 2003
    17
    Paul,
    What criteria did you use choosing your drive system?
    What gear ratio did you use?
    Thank you,
    George.
  3. #143
    Mar 2003
    6855
    Just speed and resolution running a 1/8th step and a 7.1 ratio. Got all my gears here- https://www.sdp-si.com
  4. #144
    Aug 2005
    3
    Could you post a List of materials and any other info that would assist others in re-creating this masterpiece. I would love to build one for myself.
    Lucien
  5. #145
    Apr 2005
    252
    CNCadmin:
    HELLO
    How many finishing size is your LASER machine? 24*48?
    How many US dollar USD is the price?
  6. #146
    Mar 2003
    6855
    My laser has a cut-able area of 28" x 60" and cost me about $2,500.00 +/- $250.00 all done up soup to nuts.
  7. #147
    Apr 2005
    252
    2,500 is the price which the cost sells?
    (www.Emissiontechnologies.Com) is your network?
  8. #148
    Mar 2003
    6855
    I designed and built it myself the one from Emissiontechnologies is not in the same class as mine. My laser is faster and more robust than his and half the cost.
  9. #149
    Feb 2004
    2337
    Just wondering....... Why does the laser tube need to be glass? Couldnt it be made out of other non conductive materials? wouldn that make it more robust and easier to make?
    Also, if you make the inside diameter of the tube larger, does that mean you get more power?
  10. #150
    Jan 2005
    1880
    I'm not a math major (anymore ) but half the cost? his table is 50watts yours is 100watts isn't it? and his is selling at a wopping 11999.00 and you put your together for under 3k, thats less than half isn't it?????
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
  11. #151
    Jan 2005
    1880
    Not to be a PITA but 11999 lets round 12k/3k is 25% isn't it?
    thanks
    Michael T.
  12. #152
    Mar 2003
    6855
    Half the cost would be 5,999.50 so mine would be more than half the cost 75%. 12,000.00 - 75% = 3,000.00.
  13. #153
    Jan 2005
    1880
    you lost me man. I had thought your machine cost about 3k to build all total? is this wrong? (minus labor of course )
    Hope not because I was thinking this would be my next project!
    thanks
    Michael T.
  14. #154
    Mar 2003
    6855
    Yes it cost me around 3,000.00 and I was comparing the cost to the one from emissions technology that sells for 12,000.00 and saying that my machine was half the cost which in reality is 75% LESS than the one he is selling. My head hurts....
  15. #155
    Mar 2003
    6855
    here some up to date pictures
    Attached Thumbnails Attached Thumbnails 113_1400.jpg   114_1401.jpg   114_1402.jpg   114_1403.jpg
  16. #156
    Jan 2005
    1880
    sweet dude! almost looks like you rebuilt the whole thing since the last pictures!
    I will definitely be pestering you when I get ready to do this!
    Fair warning! :P
    thanks
    Michael T.
  17. #157
    Mar 2003
    6855
    Fair warning! :P
    Not really I just redesigned the laser cutting head, that main mechanics I did not change. I added a 80/20 frame and plexi glass to help with smoke extraction. Art from Mach is help me out with getting the code right in Mach for use with lasers, all most there.... It's working so well right now and I'm learning something new, now the fun of logging what feed and power all the different material needs. The next thing I want to try is engraving.
  18. #158
    Feb 2004
    2337
    Ditto.
    Suddenly you have a small laser on the gantry. Where is the large laser tube that was sitting on the side? Have you changed lasers?
  19. #159
    Jun 2003
    1365
    Paul, how fast do you get that thing cutting and moving? its looking like a pretty sweet setup.
    it appears you have to set the z height manually with that nob? how high above the work do you set that?
    Jon
  20. #160
    Mar 2003
    6855
    Quote Originally Posted by JFettig
    Jon
    The machine will move 600 IM I depending on the material I cut a average of 200 IM. Their is no "Z" the adjustment is for adjusting the depth of field, the height is determined by the material and the thickness of what I'm cutting.
Page 8 of 13 678910
  1. Lathe auto-turret project log
    By kong in forum Vertical Mill, Lathe Project Log
    Last Post: 05-28-2015, 06:45 PM
  2. feedback isolator for laser
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-14-2007, 03:34 PM
  3. Laser tool path display....( IDEA )
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 04-11-2006, 04:19 AM
  4. Version 1 Mini Mill project log
    By mannster in forum Vertical Mill, Lathe Project Log
    Last Post: 05-19-2005, 03:56 AM
  5. Rapid prototype CNC laser resin. (Stereolithography)
    By ynneb in forum Community Club House
    Last Post: 04-25-2004, 02:17 PM
