603,813 active members*
3,336 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > New Allegro Bipolar Stepper Driver A3986
Page 28 of 42 18262728293038
Results 541 to 560 of 826
  1. #541
    May 2006
    2415
    Quote Originally Posted by pminmo View Post
    Which would the DIY'er prefer?
    I vote for 220's standing up and heatsinks above the board, with insulators it is reasonably easy to put large heatsinks on.
    Just my 2c
    Russell.
  2. #542
    Oct 2005
    1237
    Different chip but maybe the people interested in this thread could give me an opinion. Below are two boards basically the same circuit, but two different heat sink methods. One has the heatsinks above the board, but takes quite a bit of board room, the TO220's aren't mechanically supported other than the lead solder. Second has the TO220's below the board with holes in the board to be able to screw the tabs to a metal substrate. Insulators are necessary. Which would the DIY'er prefer?
    Below the board. Above the board looks like there is a problem with heat sink size issues. If what I percieve to be a small heat sink is adequate, then either, but it looks like real problems if they are marginal. Below offers a nice solid design. Robust mechanically, and heat sink choices are wide open.
  3. #543
    Apr 2006
    225
    Hi
    Does anyone got a finished circuit (tested) with the A3986?
    I just wanna find a good 6A bipolar chopper stepper driver that is open source...
  4. #544
    Jun 2003
    3312
    Quote Originally Posted by Brenck View Post
    Hi
    yes, but the problem is the 3986 chip it self has issues for most cnc appliactions.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  5. #545
    Apr 2006
    225
    well does anyone got a link of a 6A bipolar chopper driver then? open source... I dunno why maybe is my language but i tried and cant find bipolar drivers with more then 4A...
  6. #546
    May 2007
    3
    Different RC filter values
    Quote Originally Posted by Xerxes View Post
    Have you tried using different RC filter values for current sense inputs? 100nF and 100 ohms makes 10us time constant which is quite slow. I would try 1nF and 100 ohms instead.
    Hi Xerxes!
    Today I changed C11* and C13* in my project to 1nF and I tested it. I saw that the steps are still not of equal length and I think that the noises are more loud.
  7. #547
    Sep 2007
    3
    A3985
    Hi all
    I was planning to design a bipolar driver using the A3985 but am now concerned it will have simular as seen with the A3986 described in this thread. Has anyone used or know if simular problems are likely to exist.
    I plan to use it in 1/4 step, driving 8A motors, using an Atmega processor for each axis for driving milling machines and lathes.
  8. #548
    Jun 2003
    3312
    3985 has the same chopping logic, the chief difference is you can change the off time to blank time ratio. But it does exhibit to of the same issues, just not as predominate.
  9. #549
    Dec 2007
  10. #550
    Apr 2006
    225
    wow thanks a lot man...
    Have u tried the circut?
    I just took a fast look, is it chopper?
  11. #551
    Dec 2007
  12. #552
    Apr 2006
    225
    Does it uses any Programable IC?
    Cuz if it does i will need the code to program it... I dunno the name of that in english...
  13. #553
    Jun 2003
    3312
    If you go back to post 540 in this thread you will see the problem with the part this thread is based on. It's an inherent problem with the chip due to the ratio of fixed off time to blanking time. Any board based on the chip will exhibit the same problem.
  14. #554
    Apr 2006
    225
    ohh so u mean like, the board doesnt work at all?
    Isnt possible to fix the problem?
  15. #555
    Jun 2003
    3312
    The work, just with the anomoly as shown. It's a chip problem, not a circuit problem.
  16. #556
    Feb 2008
    14
    Sorry, one more question on this argument...
    If the blaking time is the problem on the a3986 (if i haven't misunderstood), what is a probable solution to this problem (not with this chip)? A smaller blanking time?
    How other microstep chips deal with this problem (other than 'ad hoc' solutions like filter, etc)?
    Thanks!
  17. #557
    Jun 2003
    3312
    Quote Originally Posted by masterx81 View Post
    Thanks!
    With the chip, a LOW supply voltage is one of the only practicle solutions, or a motor that exhibits a higher time constant. At 18V it exhibits the problem, much less than at 28V. 12V is the minimum supply voltage with the chip.
    It was a design decision with Allegro to do the time constant ratio's they did. Probably because the chip was originally designed with some specific manufacturer's requirement for some product that doesn't need the same things CNC machines would, such as the speed range needed for slow milling to fast rapids.
  18. #558
    Feb 2008
    14
    Close, the relationship of the blank time to the off time is fixed. If the current rise during blanking exceeds the current trip point when it comes out of blanking, the chip doesn't shut off till the end of the next cycle. During slow decay modes, the current decay is so little with respect to the blanking time, it exceeds the trip point before coming out banking and the chip doesn't detect it. If you increase off time, then blanking time increases, so you can't win. By going to a real low supply voltage you lower the current rise time and it's less of a problem, as it is also less of an issue if the motor has high coil resistance as well as the inductance is of a value that helps.
    Waist of time isn't half of it......
  19. #559
    May 2008
    hi.
    Where is partlist?
  20. #560
    May 2008
    hi. where is partlist?
  1. Allegro stepper driver
    By EUnit in forum Stepper Motors / Drives
    Last Post: 01-05-2011, 06:29 PM
  2. A3985/A3986 5A/50V Bipolar Stepper Design
    By NE5534 in forum Open Source Controller Boards
    Last Post: 09-23-2010, 05:39 PM
  3. Allegro A3986...Stepper Translator
    By slp_prlzys in forum CNC Machine Related Electronics
    Last Post: 06-07-2009, 07:59 PM
  4. Allegro A3986
    By Kevint in forum Stepper Motors / Drives
    Last Post: 12-07-2008, 07:53 PM
