603,822 active members*
3,673 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > New Spindle Automation activity - Help appreciated
    Mar 2010
    29
    I am hoping the group here can help me with a problem that I am having.
    I am having issue getting my spindle to run correctly whether I select CW or CCW rotation.
    I am just setting up the spindle control for the first time. Up to this point my spindle has been controlled manually at the machine.
    Here is my setup. I have a LittleMachineShop 3900 Mini Mill (Sieg SX2). It has a brushless motor for the spindle so I am using the LittleMachineShop 4213 spindle control board. I have it connected to a CNC4PC C11G BOB. I have attached my XML file for reference as well. Wiring is per diagram Chris provided with the LMS 4213 spindle.
    So using the XML posted I can get the spindle to turn CCW (M4) at whatever speed I choose. All good here. I can shut off the spindle with M5. However, when I go to turn CW (M3) I get no response at the spindle.
    So I started trying to figure out the setup a bit more. I have the following core setup:
    MY SETUP
    Kernal Speed 35,000
    Motor Outputs
    Enabled Step Pin # Dir Pin # Dir Low Step Low Step port Dir Port
    Spindle Y 14 0 X X 2 0
    Output Signals
    Enabled Port# Pin# Active Low
    Output1 Y 2 1 X
    Output2 Y 2 16 X
    ChargePump X 2 17 X
    Spindle Setup
    CW Output1
    CCW Output2
    Spindle motor output - YES
    Step/Dir Motor - YES
    Spindle Motor Tuning
    Steps Per Velocity Acceleration Step Pulse Dir Pulse
    1000 1500 31.25 3 0
    Pin Type Output
    Start/Stop 16 Electromechanical Relay 2
    Forward/Reverse 1 A/C Solid State Relay 1
    AVI (SPEED) 14 Analog Output (0-10V) Spindle
    I based this loosely on the CNC4PC sample XML and the manuals for the C11G and the 4213.
    Now, if I add a Dir Pin of 1 to the spindle setup on Port 2, I can get the spindle to turn CW using the M3, but the M4 will turn for a bit and then stop.
    I would like to be able to use M3 and M4 as necessary for tapping.
    Anyway, I am open to any thoughts and ideas as I am by no means a Mach expert (just learning as I go along).
    Mar 2010
    29
    Arturo at CNC4PC was able to get me going. He was very helpful and his products worked perfect, just a lot of user error here
    the setup in Mach needed to be:
    MY SETUP
    Kernal Speed 35,000
    Motor Outputs
    Spindle Y 14 1 X X 2 2
    Output Signals
    Output1 Y 2 16 X
    ChargePump X 2 17 X
    Spindle Setup
    CW Output1
    CCW Output1
    1000 1500 31.25 3 0
    Pin Type Output
    Nov 2009
    4415
    Dont worry, you werent the first. I too have had the pleasure of a personal call from a few vendors here on the Zone and Mach including Arturo. Stand up people and all got me going.
  1. Simple spindle automation, please advise...
    By Witsenburg in forum Servo Drives
    Last Post: 02-11-2008, 03:57 PM
  2. activity
    By Bill C in forum I.C. Engines
    Last Post: 05-12-2005, 01:11 PM
