Before I do, I'll "Take it from the top" and check everything. I have a spare TTS collect, so maybe I'll swap to that too. Its not "too big of a deal" - I don't mean to imply I'm unhappy with the machine or anything, its just that I've never seen a tool pull in nearly 20 years of being around or doing machining and was a bit surprise by it. Whenever it occurs, I back down the feed a bit and it goes away, but its a bit disconcerting. I am cutting at the maximum DOC in a radial cut with a long cutter, so that's a contributing factor. I should get my new coated carbide in shortly and I'll check how that affects it too.
